Service Manual wording confusion, CVT '21 Crosstrek Limited
1 reading
3.2K views 6 replies 4 participants last post by  DieselDorf
#1 · (Edited)
Hi all, tl:dr below
Most of my daily driving is short 5-15min trips in the Midwest on asphalt. I believe I should be following the severe maintenance schedule for condition a, and notes 1, 3, 4, and 6. My confusion is with the wording of maintenance item(s) 12(transmission gear oil) in the service manual. I'm pretty sure a Crosstrek falls under "except BRZ", but I haven't been able to find a straight answer for if my vehicle uses "transmission gear oil" specifically. I believe my CVT transmission only needs one fluid which is CVT fluid. Is that correct? The only proper gears in the CVT I can think of would be the set that handles reversing.
tl;dr
Is maintenance item 12 applicable to my '21 Crosstrek Limited?
Thanks,
Logan
edit: I have added an image of the table I'm referring to
#2 ·
CVT transaxle uses 2 different fluids. CVT fluid for the transmission AND differential fluid for the front differential. Front differential fluid is the same as the rear.
Bearing that in mind, you have 2 different drain plugs AND 2 different fill plugs for the Transmission/transaxle. And another for the front differential which you open when filling until fluid flows out. In other words lets you know when it's filled and not Overfilled.
#4 ·
Ferret,
Thanks for such a quick reply. What I understand from your reply is that maintenance items 13(CVT Fluid except BRZ & Hybrid) and 14(front and rear differential gear oil except BRZ) do apply to my '21 Crosstrek Limited, and that maintenance item 12(transmission gear oil) does not apply to a '21 Crosstrek Limited. Is that correct?
Thanks,
Logan
#5 ·
AM407,
You're correct, I'm referring to the thin booklet that tells you when and what to service your vehicle, my mistake.
Of note, the 2023 PDF that you linked does not match the 2021 booklet that was provided with my '21 Crosstrek Limited. The difference is that item 5 Timing Belt(WRX STI) is no longer present in the 2023 booklet, I assume this is because Subaru has discontinued the WRX as of 2022.
Logan
