21 - 37 of 37 Posts
Hello, I own a 2018 Crosstrek in Florida. All of my driving is done in flat nicely done asphalt.. and yesterday at 26k miles I had to replace my rear wheel bearing.
Has anyone heard of any issues with this? At this point (mileage) and with the Crosstrek?
You should have fixed under warranty a year ago.
I wondered about this when I got steel rims for my snow tires and made sure I got 48 mm offset rims. I'm at 230,000 miles now - replaced first bearing at 170,000 miles and replaced the other three and the propeller shaft at 200,000 miles. That's consistent with other vehicles I've owned - bearing start to go around 200,000 miles for me.
Sounds like evidence to me. Only other factor I can think of is weight. Changing weight would probably impact durability. Thanks.
Yep. My rear driver side bearing had to be replaced at 25K miles.
I just had mine replaced this week. Also in Florida, 33k miles on a 2018 Crosstrek. Thankfully it is still under warranty.
I have a 2018 Crosstrek. At 32000km the left rear wheel bearing was replaced. All covered under warranty. The never mentioned anything about a TSB. But reading that TSB suggests that both should have been replaced at the same time. Wonder if this TSB applies to Canadian models?
All the Treks come from the same factory in Japan, so I assume this TSB would apply to your vehicle.
If you read the TSB carefully, it doesn't call for both bearings to be replaced if only one is acting up. What it does say is that on any single wheel the bearing and backing plate must both be changed as a set.
As an aside we don't have a law in Canada that requires auto makers to provide free access to TSBs that apply to Canadian vehicles. You can access the TSBs for Canadian Subarus via the Subaru.ca site but you have to pay a subscription fee. FYI here's a little history on how it took the threat of a lawsuit to finally get American TSBs posted for free on the NHTSA site: How to Get a Free Technical Service Bulletin
I stand corrected. I did miss read the TSB.
Ahhh,, and, Hello Homies: I stumbled onto this site and forum rather incidentally, , after I googled Low Growling on 2018 Crosstrek:: I own a 2018 Subaru Crosstrek; sitting right at 45,000 miles.. Just today I elected to look furthing into my car's issue and upon Jack-Standing the rear axles - I will very likely discover the 'rear' wheel bearings are in need of replacement.. Do it ye-self thing: after watching the U-Tube video on 'bolt-in' rear subaru wheel/axle bearings,, I am thankful at this time and place that RUST is not an issue to replace the bearing on my vehicle... less than 200 dollars for parts and perhaps another 45-50K... time will tell.. Also,, in Florida and my driving is basically paved asphalt roadways.. Nice to compare Notes!! @ Peace.
I have a 2019 Crosstrek, My left rear wheel bearing was replace in 2019 ( with about 20K miles on my car) and now it has gone bad again with 42K miles on my car! Highway and freeway driving only, no off roading :(
should I be worried? dealer replaced both times under warranty.
I bought my 2014 XV used at 47k miles. I’ve never had issues with another car like I have with my Crosstrek. Previously had a Honda Insight and had literally ZERO issues up to 100k miles.
When I bought the car I noticed the brakes get sticky after stop and go traffic. The whole front end shakes like you have a flat tire. Other owners have experienced this but the problem can stem from many issues, to the brake assembly to the Axles. The problem comes and goes…dealer can’t diagnose.
At 55k miles the left rear bearing went. $750. At 60k miles 6 months later the same left rear bearing failed AND the right rear, at the same time. Dealer covered the one they just replaced(left) but the right one set me back another $750. At this time as well the A/C compressor failed $750. This car has a great community and it’s a fun car to have but god Subaru screwed the pooch on this car. Next car will be an Outback, that model has it’s actually together. Fingers crossed these bearings make it at least 20k miles.
spoke to my father about the problem and he told me he’s never had a bearing fail on any car he’s owned. Friends and family have confirmed they’ve never had issues either. I suspect it’s the suspension design. You may notice when you go over a bump in the Crosstrek while banking on The highway you’ll notice the car kind of sways out and back into alignment. Like a snake sort of movement that I’ve never experienced driving another car. This movement puts a lot of lateral stress on the hub assembly, I can imagine. Resulting in damaged bearings. Just my two cents.
I own a 2017 Crosstrek, 70k miles and just had to have both front axles replaces as well as both rear wheel bearings within 6 months. Was going to trade in for a new model before this happened, now I'm wary of getting another Subaru.
2018, 134,500+ mi, both passenger bearings swapped in the last 20,000mi and about to buy the other two, can't tell but the front sounds like it might be starting to whir. The rear looked pretty rusted when I did the rotors and brakes so might just do them both at once.
21 - 37 of 37 Posts
