Ok,it was out a few months to a year tops.That's not long enough to make a difference.It's still "new" and thus there were issues that still did not surface until recently.The valve spring recall,AC pump issues and brake light switch for example.I waited and got a '16 which has all the major bugs worked out.Even the brake light switch hasn't given me any issues even though it's on the list for the recall.The point is that it was too soon in the production run and thus he didn't give the product a chance to mature.That's the bad choice that was made.But that wasn't the first year of production... MY12, which was initlally sold in Australia, was the first year of production for the Crosstrek. The FB20 was also in MY12 Imprezas which was sold world wide.
You could always drive it like you stole it for the next few hundred miles...I finally got my car back yesterday! They had it from May 27th until July 18th... Yeesh.
Well, it runs. So, so far so good. Here's hoping they didn't clog the oil channels and it doesn't blow up within a few hundred miles.
Good luck selling your car if all warranty work s not completed!oh GREAT, yeah let's trust a Subaru mechanic to replace my engine springs, they cant even rotate tires correctly. This will just lead to poor/shoty work that will eventually fail. This car is 100% getting dumped before warranty is up.
woah ? That’s really bad. I would definitely point my finger at Subaru for a new engine.engine failure following spring valve replacement
New here but thought I would give a heads up about a possible issue on my 2013 Crosstrek, had my recall work done July 2019 to replace spring valve, as of October 2019 I have no car, engine is blown. From a short drive to the mailbox to my work, the traction light came on, oil pressure, engine light, loud ticking started, shut it down, I live very rural so no where near a Subaru shop, towed it to the closest mechanic, let me know that I will need a new engine. Due to the cost of the engine repair to replace with a used engine I won't be able to afford to fix it, and the reality is I won't be able to afford to get it towed to the city to a Subaru shop to be told the same thing and then have to tow it back home to try and sell it as is. I don't know for sure if it due to the engine being removed to have the spring valves replaced, and installed incorrectly, but something people should be watching in case a trend starts happening. Saw a few articles that a class action lawsuit in USA, Has started as its been the concern that this recall has caused significant engine failure afterwards.
Just had my car back to Subaru to identify their leak and they have said it is leaking from a driveshaft gasket that must have been nicked when they reassembled it.woah ? That’s really bad. I would definitely point my finger at Subaru for a new engine.
I had mine done 7 weeks ago and I just noticed that it is leaking oil from the engine bay. I’m not sure whether it’s engine oil, cvt fluid or something else. It had a major service done at the same time where they replaced a lot of fluids so who knows. It’s going back on Wednesday for them to look at it.
I don’t have much confidence because they’ve had my engine out a few years back to fix an oil leak under warranty. After that the engine had a loud tick which turned out to be a bent camshaft.
It is a massive job taking engines out and back in and I wish I’d never done this recent recall now.
Replying to my own post...Got my letter last week from Subaru Australia. Called up one of our local dealers to book in for a service. Direct quote "...we're booking into 2020...". :shocked:
They've taken my details and will call back in a few weeks to confirm my place in the queue.
One interesting piece of info they gave was that only Master Technicians are allowed to do this work, they only have 1 in their workshop and so they can only do 2 cars per week.
Lost Nuke...oh no....This is my biggest worry. I don't know the reputation of our Broken Arrow dealer, but the next closest one is 86 miles away in Fayetteville, AR. If mechanics get under pressure trying to take care of all the recalls, there WILL BE problems after the fix depending on its complexity. I don't want to have to deal with that.
To change a valve spring I am assuming that only the valve cover will need to be removed. But will that entail lifting the engine out? I certainly hope not!
