41 - 43 of 43 Posts
Cherrytrek, where did you see the 1.2%?
I found several (non brand specific) charts showing 2” down at 25’ which is 0.6666%.
The manual for my 2024 (LEDs) shows how the screws work, but no angle/height/distance info.
I‘ve found Subaru info saying to be 30 feet back, but again, no other info.
The 1.2% is molded into the headlight housing. I found some 2024 Sport/Limited headlights on eBay with a picture that shows 1.2% as well, just in a different location. I'm curious if the sticker on the 2024 has different aiming adjustment instructions. I couldn't find a clear picture of the sticker online.
The blue square is for horizontal (azimuth) adjustment. It's very fine - you need a massive amount of complete rotations so as to notice the pattern moving. It's purpose is to direct the V-like notch in the beam pattern at the right angle towards incoming traffic, so that it intersects with the same V-shape of the other headlight on the ground (preventing to illuminate incoming traffic).
The horizontal adjustment screw one is the identical white thingie to the LEFT of the blue square (arrow). Notice how there is a (diagonally to the right) groove in the plastic assembly, allowing the insertion of a screwdriver.
So there is only one U-D screw on each side? (The yellow arrow).
And we ignore the Red square adjuster?
(there are two U-D, U-D marks on each housing - and a sticker says to “adjust both at the same time”).
Thanks for the picture. I stared at the two adjusters for a while last night and deduced incorrectly which was which.
41 - 43 of 43 Posts
