Engine Whine at 100km/hr...
40K views 63 replies 33 participants last post by  Ice
I'm lucky enough to have purchased the XV 2.0i 6-speed manual back in March here in Australia and so far pretty happy with it.
However, ever since I have had it I have noticed a constant whine when doing about 100km/hr. It's noticeable and constant at that speed and seems to decrease as you slow down or speed up from 100. The whine doesn't change pitch with the accelerator, just changes pitch when speed increases/decreases.
I don't notice the whine at other speeds and occurs in either 5th or 6th gear.
I have had Subaru check it out twice and the first time said it wasn't a problem, then a manager experienced it a second time and said that 'some cars do this and some don't'. Obviously I want one that doesn't.
Anyone else had experience with this? I've read some reviews that mention similar a similar whine. I drive on the highway to work everyday (100km round trip) and it is the only annoying thing about it - the constant whine is very noticeable. I also have several rattles, but happy for them to be fixed at the next service.
Any comments or suggestions would be appreciated...
#2 · (Edited)
The FB20 engine is chain driven, hence the whine. You may want to check out the Forester with the same engine perhaps?
My experience is that the whine in my CVT is during hard acceleration but when cruising up to 150kph, it's very silent.
#3 ·
Thanks arnoldc - I have heard that it may be the chain-driven engine. However, most of the posts refer to the noise being heard whenever they are accelerating ie- when the accelerator is pressed.
I can only here mine at around 100kmh and does not change if I take the foot off the accelerator - it is constant and only decreases in pitch as the car slows down.
#7 ·
@varsuda, had an opportunity to test again at exactly 100kph yesterday, for a stretch of about 15km x 2 (back and forth on the expressway), and I'm sorry (for your XV) to say my XV is very quiet in that condition. I also engaged Cruise Control for about 6-7km just to test if it has any effect, but car is still silent.
#8 ·
We have done a1000km in the last two days and no whine. Took the Thule roof bars off to stop the whistling after 300km. Some very smooth bitumen surfaces can change the tyre noise to make higher pitched sounds! Do you think it could be from the tread pattern of the tyres?
#10 ·
Awesome I'll have some tails soon
Going to QLD in 4 weeks time towing a camper trailer ( got to have some tail there)
Then off to the Snow for 2 days ( I'll share all my awesome tails )
Can't wait to test out this awesome beast
#11 ·
Thanks arnoldc it's good to hear yours is fine...goes to show that some do it some don't. @debath - pretty sure it's not the tyres - the sound has no real direction it just kinda fills the cabin. I do hear some road noise but nothing unexpected when on a highway. The rattle from the dash is getting worse though, so hope that gets fixed properly at the 12k service.
redskiesoverparadise - I had heard that the CVT had the issue as well, but sounds like yours is not one of them!
Be good to hear others issues as well, I'm sure sheep and I aren't the only ones. Kinda getting sick of Subaru telling me it is normal is some vehicles; just wish it wasn't mine...
#12 ·
I too get the same whine at 100kph, sounds more like mechanical than aerodynamic. Thought it was coming through the sound system at first but switched that off and still there.
#13 ·
Thanks redskiesoverparadise for the advice and will look into some of it. However, have to agree with ppk88 in that it sounds more mechanical. The noise disappears after about 105km/hr which might suggest it is not aerodynamic. However, keen to give anything a go and will let you know...
I have had a passenger in the vehicle and they have not been able to place the noise directly, though it is worth trying again.
ppk88 - be good to know what you find out about your whine.
#23 ·
I took my 2 week old car into the dealer for 3 things to be checked: wheel alignment which was slightly out and causing the steering wheel to be slightly turned to the left, dash rattles and "the 100kph whine".
They fixed the wheel alignment and rattles and reported that their initial impression was that the noise was the timing chain, but when they checked the Subaru website there is a dealer advisory note saying that the 100kph whine is coming from the transmission and is currently under investigation by Subaru. The dealer said the wording implies that all the manual transmission XVs have it but not everyone can hear it.
I suggest that if you have the whine you register the fact with your dealer asap so that if they come up with a fix it is known that you and your car are among those affected.
#24 ·
Mmmm, thanks for that info Gail. That was my theory, whine is specific to the manual transmission. Very astute of your dealer, do you mind telling us who the dealer is? Other people in your area might want to take their XV there!
Keep us posted on any more information you get. I guess the Impreza has it too, being pretty much the same?
#26 ·
Thanks Gail for the info. I have the manual and you can add me to this growing list who have noticed the 100kpm whine. I can hear a hint of it at lower speeds too but it is definitely most prominent at this speed. This is my first Subaru so at first I thought it was just the way the boxer engine sounds but apparently this is not normal like the "growl" people talk about.
