21 - 40 of 419 Posts
Looks like red lug nuts but the car looks raised. True?
I'm curious, is it possible to put on wider tires on the stock 17s just to give it a little more rugged/sporty look?
225/15/17 are stocks how wide could I go?
Probably could but I don't think it will give you the look ur after. Really would want a wider wheel, with a properly fitted tire.
Not my area of expertise, but i think you might run into problems with running a much wider tire since the side wall is so short. Maybe if you dropped to the 16" wheel you could put something wider. I don't think that you would gain a whole lot from the small width increase you could get.
The issue is going to be clearance. I know there are some older threads about what the biggest tire you can stuff in the wheel well is. What I plan to do is eventually buy a set of 16 inch wheels with tires that are as close to the stock diameter as possible. This will give a taller side wall while avoiding the issues of clearance and spedo inaccuracy. The down side is I really like the stock wheel, I just wish they had made it in a 16 instead.
Thanks, I guess I'll wait around to see what others do... I'm certain someone will be putting on off road tires.
I did speak to a rep from TireRack and he told me I could go as wide as 255, which was a surprise, yet he wouldn't say if I could go up to a 60r
Colleagues at work told me I could probably go as high as 65r but no wider than a 245 so lots of conflicting answers is making this even more confusing. I did find some Toyo Open Country 235/60r/17 which could work I guess, but for now I'll wait around
These were left over after I traded in the Baja Turbo. 225/55-17, just as the stock wheels, but 13mm further out (ET35 vs stock ET48).
Yokohama Advan Sport. Perfect for some "konbana" as we call it here. Think you americans call it auto-xing.
