'16 Key Fob Issue
3.9K views 11 replies 6 participants last post by  SunnyV
Hi everyone,
I've had a similar problem occur multiple times now, and I'm running out of ideas. I haven't taken it to the dealership yet, as I'm guessing they'll want to replace the fob's battery. Anyway, here's what's happening.
When my car parked, I enter the car (either unlocking it first, or if it's already unlocked), sit down, push the brake, and try to start... nothing. The green light won't light up. I can take my foot on and off several times, nothing. I have gotten out of the car, locked it, unlocked it (with the door handle keylessly) and re-enter, still no green light. The couple of times that this has happened I have ended up gettin gout of the car, locking it and walking away (15ft) then return to the car, unlock, and then it will work.
I don't think it's my fob's battery as it is locking and unlocking the car just fine (with proximity and touch, not using the buttons). Has anyone else had this problem? I have had issues if the fob is near my phone, but that wasn't the case the several times this has happened recently.
Thanks!
#2 ·
Has the battery been replaced before? If not, it may be due (probably three years since the car was made). You should be able to change it yourself for a couple of bucks although I've only done that on our Lexus and Honda. Not sure how user-serviceable the Subaru fobs are.
#3 ·
No, I haven't replaced it before. I'll have to look into how easy it is to do myself. I still find it odd that it's unlocking and locking just fine, makes me think that something else is causing the problem.
#4 ·
This is just one reason I want nothing to do with vehicles with push button start.There are those who have had this issue and those who will have this issue if they keep the car long enough.Another reason is that your key fob is constantly sending a signal in an attempt to communicate with the car.Thieves now days have a machine that can receive,store and reproduce that signal and all they have to do is get within range of the fob.Once they have that signal they can drive away with your car like they owned it and the car won't know any better.So the only permanent fix is to trade it in on a car with a real key.Just one more reason why I will be holding on to my '16 premium,with a real key,for the foreseeable future.
#5 ·
Even the "real key" cars have this problem. The '02 Lexus we replaced with the '18 Crosstrek would not start unless the electronic part of the key was attached to the actual metal key. We learned this when the plastic part of the key containing the electronics broke off (it eventually happened to both of them).
#10 ·
If you have a second fob, try it.
Reactions: AstroKats
