Tyre pressure light on even if pressure is ok
7.5K views 4 replies 4 participants last post by  Andrea885
Owner of Subaru XV 2023 1.6, this morning tyre pressure light turned on, display saying "low pressure".
The dash showed both rear wheels "orange", pressure 27-28 psi. (front wheels around 30 psi)
Front wheels pressure ok.
I've check and inflated rear wheels at above 2.3-2.4 bars, then turned of the car.
So I tried to drive for a few kilometers, the pressure showed on the display moved to around 30 psi, but pressure light is still on, showing the same pressure issue.
I tried to turn off and on again some times, no result.
Any suggestion? Do I need to go to the dealer?
thanks
Andrea
Discussion starter · #5 ·
Thanks for all your feedback.
I keep pressed TMPS button for a few second, with key ON, engine OFF and set it to TMPS 1.
Pressure on the rear tyres 30 psi.
Now it seems to be ok
I'll let you know if finally working properly.
