Got my 2024 Crosstrek Wilderness about a month ago but only recently had opportunity to drive at night. First, seeing the lights adjust and align at engine start is pretty cool. As well as seeing the lights adjust for corners. Pretty sweet! But I noticed something peculiar regarding alignment. Now bear with me. When driving there are two dark spots where the headlights shine BUT they appear to be in front of the driver side. This is not a problem because you see the light spot around the dark spot (I hope this is making sense). Now, when you turn left, you see the dark spot angle to the left, taking the light beam with it. Straighten the wheel and it comes back in front of the driver side. Here's the issue. Turn right, and again the dark spot angles to the right, but returns to the driver side when straighting out. I feel like it should either return to a place in front of the passenger side, or they both should be centered between the passenger and and driver. Is it just me, or does this seem misaligned? Or are the headlights aligned to be more in front of the driver? TIA.
