Called the dealer to see if they still had blue filters as they were getting white one in a while back. Was told there is a new blue filter..they claim it is of much better quality than the old one.
Amsoil filters are double what they should cost. But they are 99% at 20 microns. Subaru's filters are at least 30 microns at 99%I switch to Amsoil filters - EA15K13 - the Amsoil filters are built like little tanks - I was impressed. They are made in the US - but I am unsure of the manufacture. I might cut one open to see the internals. To stir the pot a little more.... I only use Redline 0W-20 in my cars as it's an ester based oil with high levels of moly and zinc.
I purchased a case of 12 filters, with my "Amsoil Discount" it came out to ~$15 a filter. That's close to what I see the Tokyo Roki filters going for on ebay - which then you have take a chance on them not being counterfeit.Amsoil filters are double what they should cost. But they are 99% at 20 microns. Subaru's filters are at least 30 microns at 99%
Just had oil/filter changed on my 2023 Limited. Out goes my Tokyo Roki....
New BLUE Subaru filter # SOA6351520812 was stamped on the top.
Now I have to find the alternate Tokyo Roki for this new BLUE filter for the Limited 2.5
And to think I tossed what was left of a case of Tokyo Roki filters I used for my 2013 Outback in the trash.
I think they may have given you the shorter, wrong filter? I believe the new part number for the Crosstrek is SOA6351520815. (Note the 12 vs 15 at the end).Just had oil/filter changed on my 2023 Limited. Out goes my Tokyo Roki....
A few months ago I ordered the following six-pack on ebay. Upon receipt I inspected them carefully for the characteristics that Mr. Subaru says to look for to avoid getting counterfeits and they appear to be genuine: Pack 6, Genuine Subaru Engine Oil Filter & Gasket Legacy, Impreza MADE IN JAPAN | eBayNow I have to find the alternate Tokyo Roki for this new BLUE filter for the Limited 2.5
Right on top it shows : SOA6351520812@Deansi...I agree with with DSM above. Your factory Roki filter should have been part # 15208AA160. The previous SOA replacement filter was 15208AA15A which was recently replaced by SOA6351520815 according to this TSB:
Damn didn't catch that one.....interesting.I think they may have given you the shorter, wrong filter? I believe the new part number for the Crosstrek is SOA6351520815. (Note the 12 vs 15 at the end).
Same source I used for the Tokyo Roki filters. Indeed, they are the real deal, not knock-offs.A few months ago I ordered the following six-pack on ebay. Upon receipt I inspected them carefully for the characteristics that Mr. Subaru says to look for to avoid getting counterfeits and they appear to be genuine: Pack 6, Genuine Subaru Engine Oil Filter & Gasket Legacy, Impreza MADE IN JAPAN | eBay
And these are correct for the 2.5 in a 2023 Limited?Same source I used for the Tokyo Roki filters. Indeed, they are the real deal, not knock-offs.
As far as I know, all subaru's have used the same filter for like 25 years. I am seriously scratching my head over this. If the threads are right and the gasket dimensions are right it will work. Correct me if I am wrong.And these are correct for the 2.5 in a 2023 Limited?
The 3.6 uses a different filter FYI.As far as I know, all subaru's have used the same filter for like 25 years. I am seriously scratching my head over this. If the threads are right and the gasket dimensions are right it will work. Correct me if I am wrong.
Then why does the Subaru TSB said "All Vehicles"?The 3.6 uses a different filter FYI.
Yea you are right!The 3.6 uses a different filter FYI.
It's nowhere near 25 years. Subaru switched to the 15208AA160 (factory)/15208AA15A (dealer) oil filters when the 4 cylinder engines transitioned from the EJ to FB engines around model year 2011. (Crosstreks have always had FB engines). The EJ's used the shorter 15208AA100 (factory)/15208AA12A(dealer) engine oil filters.As far as I know, all subaru's have used the same filter for like 25 years. I am seriously scratching my head over this. If the threads are right and the gasket dimensions are right it will work. Correct me if I am wrong.
