Hey Mates, I’m having an issue solving the P0171 Lean Bank code.
I’m in a 2015 Subaru Crosstrek A/T. 51,000 miles. Typically use 89 gasoline.
Solid check engine light and traction control light are on. Engine trembles or shakes a bit (rough) when idle. Traction light turns off sometimes, and check engine will even turn off sometimes. But always comes back when I fill the tank.
I took it to my mechanic. He’s a Honda specialist but I still go to him since he’s been my mechanic for 20 years. He checked everything, no hose or intake leaks, no cracks, he couldn’t find the issue. He even cleaned the ox sensor. He said if the light stays on, I should take to Subaru or Subaru specialist, but before I do that, I wanted to ask you all if you have any ideas.
Has anyone experienced this same situation? Anything I should do or check before I go to Subaru?
Thanks!! -AA
Thanks!! -AA
