If anyone can help... I don't fully understand how to operate the high beams in my new 2025 Limited.
In our 2024 Outback Touring, with the switch set to AUTO, when I push the light stalk forward, the stalk stays in the forward position, and the high beams are engaged with High Beam Assist. To turn the high beams off, I pull the stalk back to the center position.
But in my 2025 Crosstrek Limited, it doesn't work that way. I always have the switch set to AUTO. When I push the stalk forward to turn on the high beams, the stalk always returns to the center position. Yes, the high beams do go on, and I see the green HBA indicator on the dashboard. And when I pull the stalk toward me, the high beams do go off... but the HBA indicator stays on. That's what I don't understand... doesn't that mean that the high beams will go back on again at some point? How do I turn the high beams off if I don't want them to go back on at all?
The other thing that confuses me is that if I push the stalk forward again, the high beams go on, and the green HBA indicator goes off.
I have tried to decipher the owner's manual, and I'm just not having much luck. Can anyone help me to understand how to control the high beam behavior? Thank you so much!
Ed
Ed
