Mye dealership will change the EGR valve. But is it difficult to clean it instead? Lot of work?
Thank you!If you have the right tools you can remove the EGR without removing the intake manifold. Of course it’s a tight area to work with but it’s possible.
I would remove the manifold and replace the EGR or clean it out, and while you have the manifold out you can clean your intake valves.
