DIY - TWM Short Shifter Install on our XV
27K views 29 replies 15 participants last post by  Jack Stilts
#1 · (Edited)
Good day All,
This is our only real performance modification that will be made to our 5mt XV. We decided before we even purchased our XV that the previous Subaru Manual Transmission throws were excessive and a bit sloppy, so this was a matter that we wanted to resolve.
We were able to install the TWM Short Shifter on our XV and this is as much as we could document outside of the TWM provided directions. The install is almost identical to the ‘08 through present Impreza and WRX installs, with only a few differences. There are several YouTube videos if the pictures aren't working for you and I have provided the links below.
This is a modification worth the time and money, I think about $163 for the Shifter and $5 for the grease, plus freight. Google search TWM promo code to find free shipping, it is out there. The time required will be approximately 50 minutes if you don’t stop and take pictures.
We also purchased the Front Stay Bushing but have not installed the bushing yet due to time and exhaustion today. The black front stay bushing is pictured as a size reference, but it was not the bushing that I thought would replace the factory center eye bushings in the actual shifter arm. The Front Stay Bushing is not financially worth returning, so maybe someday I’ll install it or resell it.
The overall feel is much more mechanical, an improved forward shift knob/hand position, and after she breaks in we will get to enjoy her. With just over 200 miles on the shifter she is beginning to smooth out.
Here is the link for the TWM page with a downloadable .pdf for the install instructions that they provide:
Subaru Impreza Short Throw Shifter
These are two YouTube videos that are helpful to watch:
How To Install a Short Shifter for 09 WRX - YouTube
08+ WRX/STi How to Install Short Shifter - YouTube
Enjoy the readings and the images.
#2 · (Edited)
Just a few comparisons for the shifter locations for Neutral, First, and Second.
1. Just double check all the parts when you receive the box. I would recommend buying the grease if you don’t have any because you won’t get much off of the OEM Shift Arm.
2. Get all of your tools ready to make sure that you have everything. I decided to use my ¼ inch socket set so that I don’t over tighten bolts. No bull in a china shop syndrome. Just as a side note, if you have a pair of fine needle nose pliers with the biter grips on the inside then you can omit the snap ring pliers. My fine needle nose pliers were SMOOTH and they DID NOT WORK, I couldn’t get a solid grab on the eyelids of the snap ring. Pictured I used the following: Rubber gloves if you prefer, Short 12mm Socket, 12mm Closed Wrench, 10mm Socket with a Short Extension, the Snap Ring Pliers, Small Phillips Head, and a Medium Flat Head.
3. I would recommend starting with the removal of the E-Brake Boot, this is the most frustrating part. I tried to use interior tools to loosen the top mounts and this failed miserably. I found it easier to simply slide my hand between the seat and the lowest rear point of the e-brake boot, towards the back seat,t and Pull Out towards the Driver Seat and then UP towards the roof. There are Two (2) retainer clips on the inner driver side of the panel and Three (3) along the top visible mid-line of the E-Brake boot. I have a picture of the internal clips of this boot. Leave the Boot on the E-Brake handle, it will get in the way every so often, but it is not worth completely removing for this install.
4. Now slide the seats forward a bit so that the Rear Console Back Seat Area is exposed. Here there are two lower exterior Pop Panels visible, one on the driver side and one on the passenger side. Again, the trim tools failed and the good old hand method worked better. Pull the Rear Console panel out a bit and slide your fingers up and under the panel to simply Pop these little Quarter Sized Panels out. Behind it you will find a 10mm Bolt on each side that will have to be removed. Now that the Rear Rear Console Bolts are removed, slide the seats back again and move to the Front of the Rear Console.
5. At the Front of the Rear Console, just before the actual shift panel cover is located, you will see the Little Metal Phillips Head Screw that was previously covered by the E-Brake Shifter boot. Remove this screw and put it in a secured place on the Driver’s Side floor. With the Screw removed there is One More Push Panel Clip on the Passenger side that you need to Pop by Lifting the Entire Front of the Rear Console towards the roof. It is straight up, so grab both side of the Front Rear Console so that you don’t crack the panel. At this point the front of the Rear Console is loose, I simply flipped it back and rested it against the back seats so that it was out of the way.
6. You can now move onto the Lid of the Front Console Removal. This is where the videos are actually helpful to watch. There are Six or so Pop/Push tabs that hold this Lid Cover in Place. Start by Lifting the Lid Cover closest to the hole where the screw was. It will eventually start popping out. Once you get the Six or so push tabs out, it is best to Start loosening the Shift Knob, WITHOUT fully sliding the top lid cover off yet.
7. The Shift Knob on the XV is actually really genius. There is a Plastic Spindle Ring attaching the Vinyl Shift Boot to the actual Shift Knob. I do not know how it works because I didn’t take it apart. What I found is that you can grab that Plastic Spindle through the outside Top of the Shift Boot and spin the Shift Knob Separately. This will prevent the Shift Boot from getting All Twisted Up. Keep Spinning the Shift Knob until it comes off the threads, this seemed like it took forever because of how long the threaded shaft of the Shifter Arm is. Once the Shift Knob is loose, LET IT REST ON THE SHIFT ARM, do not let it flop around because it may tear the shift boot.
8. You can now pick-up where number Six left off. To completely remove the Top Lid Front Console cover you need to pull the Front Front Console Retainer Tab Down at a 45 Degree Angle and Back towards the Rear Console at the same time. Wiggling it a bit helps, but remember, NO BULL IN A CHINA SHOP or you will break the retainer tabs. Once it is loose you can remove the lid, remember to Hold the Shift Knob because it will fall wherever gravity takes it. Put this Top Lid Cover for the Front Console in a Place that you will not scratch it.
9. Next it is time to tackle the actual Shifter Arm. There is another Rubber boot covering the mechanical area of the shift arm. There are two White Threaded Caps that hold the boot down. You can use the Medium Flat Head or your fingers to loosen and remove the tabs. I am not sure if you can simply pop them out or if you need to untwist them, that will be your decision. Remove the white tabs and Pull the Rubber Boot Back and Up to remove it. The Front of the Rubber Boot rests UNDER the Carpet, so remember that when you reinstall it.
10. With the Rubber boot removed you can now see the Mechanicals of the OEM Shifter Arm. **MOVE the shifter around
to get a good feel for it. Feel and Watch the mechanicals for smoothness, any sticking points, etc. This will be useful for reinstallation purposes** The Bolt Head is on the Left Driver’s Side and the Nut is on the Right Passenger Side, remember this is a US XV . **COUNT THE NUMBER OF VISIBLE THREADS and Take a picture of it so that you don’t forget it.** The directions say 10-12 ft/lbs of torque, I did not waste time with the torque wrench and simply retighten the bolt to the same spot on the reinstallation. If Subaru feels that is adequate then it works for me. If you have a second vehicle and the time I would recommend going to a hardware store and purchasing a replacement Nut with a Plastic Retainer built into it, this will reduce the likelihood of it ever loosening up again.
11. You will need to remove the Bolt with your 12mm Short Socket and the 12mm Wrench. Once the nut is off slide the bolt out. Again, put this where you won’t lose it, passenger floor if you want.
12. The second most frustrating thing is to remove the Snap Ring. You will squeeze both of the Eyelids TOWARDS one another. This will take several attempts and expect the snap ring to SPIN around and move with each failed attempt. Once the snap ring has agreed to release itself, slide it up the lower shaft of the Shifter Arm, this will get it out of the way.
13. I spun the Shifter Arm around several times to loosen the grease suction that is on the White Pivot Joint Plastic Piece. I am certain that there is a technical name for this artificial joint/socket, but I don’t know it. The next part is fun, simply LIFT UP on the Shifter Arm to remove it, twist and pull. It will dislocate and pop out. Now get those rubber gloves on because it will get greasy.
14. It is time to swap the hardware from the OEM shifter to the Short Shifter. Give the Snap Ring a mild Twist to remove it from the Old Shaft. Take the Medium Flat Head and Push the Center Metal Shaft out of the Circular Center Joint of the OEM Shift Arm. Once the shaft is removed you can see a Small Gap between the Two (2) Stock Plastic Circular Joint Bushings. I would recommend using some type of Spray Lube to get these Hard Plastic Bushing Out. This will take some force to remove these because they are snug. Work the bushing out, DO NOT TRY TO PUSH in the same spot the entire time. You will have to work it from the OPPOSITE side at a 45 degree angle and in a Circular Motion. Once you get the first side out the second side is a bit easier, you’ll get a straight shot at the bushing. Last and not least you can simply twist the lower White Joint and it will pop off, this is the GREASEY Step. Once the white joint, both bushings, the shaft, and the snap ring are removed it is time to install the hardware on the Short Shifter.
15. Before I reinstalled any of the OEM parts I used a fair amount of the purchased grease on and in everything. You can use your judgment if you want to do this or not. So stop reading and get the Short Shifter Arm rebuilt with all of the factory parts. Don’t forget to install the Snap Ring, it is easier to do out of the car as versus in the car.
16. With the Short Shifter reassembled bring it back into the car and put it on a shop rag that can be thrown out. **I would recommend putting some of the Grease Lubricant on the Mechanical Shift Arm that goes through the body towards the Transmission.** Do this BEFORE you Install the new Short Shifter, it is MUCH EASIER TO ACCESS. I have provided a picture as a reference. Some people complain of the Mechanical Arm rubbing against the Gasket and creating a squeaky sound. While it is apart do it now and prevent a future nuisance.
17. If you want to put some grease in the base of the circular floor pan where the white socket was removed from do it now. To get the White Joint Socket back into the opening simply Pop it back in by putting a Downward Pressure on the arm. You can do this by hand, DO NOT USE a Rubber Hammer, it is an overkill. If you can’t do it by hand then it is not aligned properly. Once it pops in the Snap Ring is ready for reinstallation.
#3 · (Edited)
18. The Snap Ring is anything but easy to get it to seat properly. I found that it is easier to squeeze the eyelids together and try to feed One (1) side into the groove first and press it down to seat in a Circular Motion. Clockwise or Counter-Clockwise doesn’t matter. You can press the Ring Down with the Small Phillips Head or the Medium Flat head, it is your choice and depends upon what is handy. This again may take several attempts. There will be many failed attempts or you can get lucky the first time. Once the Snap Ring is Secured and in Place give a Strong Forceful UPWARD Tug on the Short Shifter Arm, this is to double check that it doesn’t pop out again. You don’t always shift gently, so give it a solid pull before you find out the hard way that it didn’t Snap into place.
19. Again, putting grease inside of the bolt shaft is your choice, I did to reduce future wear. With the Short Shifter secure and in Place, Line Up the Mechanical Arm with the Center Bore of the Short Shifter, Place the Bolt through the Mechanical Arm into the Shaft from the Left Driver’s Side, aligning the arm with the bolt may needs some manipulating, and feed it all the way through. Reinstall the Nut on the Bolt with the 12mm Socket and Wrench, again **COUNT THE NUMBER OF VISIBLE THREADS**, did you write it down, if not look at your picture again. If you overtighten the nut the shifting will feel and sound wrong. This is how I judged how tight it is. **I also felt and watched the mechanicals, nothing seemed to be restricting or sticking compared to the OEM shift arm, so I left it and continued with the reinstallation.**
20. Reinstall the Rubber boot, remember to tuck the front of the boot under the carpet. Install the two white plugs.
21. Feed the Top Lid Cover of the Front Console into alignment, rest the Shift Knob on the Shifter Arm, Snap the Front Retainer Clips into the Front Console, and press the other Six or so Down into position. Go ahead and grab the Spindle at the Top of the Shifter Boot and Tighten the Shift Knob. Remember that it will spin forever, it will eventually tighten down. Now is a good time to angle the Shift Knob so that is comfortable. Go through the gears again to make sure that everything is good before you finish the job.
22. Lower your Rear Console back into Place. Remember to Press Down on the Front Pop Clip of the Rear Console. This is your alignment Guide. Reinstall the Small Phillips Head Screw underneath the E-Brake Cover. Move the Seats forward and Reinstall the two (2) 10mm Bolts. Push the two Black plastic cover panel over the rear of the Rear Console. Slide the seats back again.
23. The E-Brake Cover can be Tricky. I found it easier to align the Two (2) Lower Retainer Tabs and then to put Downward Force onto the E-Brake Panel to get the top three to seat properly. You’ll figure out what works for you because the hard parts are over.
24. It is time to take a test drive and enjoy your Short Shifter. Some things may feel Wrong at first, it may just take some getting used to, you be the judge.
I hope that this has helped a few of you decide if you want to do it, pay someone to do it, or simply keep running what Subaru has provided for you.
Dan
#10 ·
We actually ordered it directly from TWM. It took about 7 business days to get to SC, it ships from Canada. Well worth the cost. Do a google search for free shipping to save about $15 in freight. If you have any questions feel free to ask and I will try to help out.
Dan
#13 ·
We did order the Front Stay Bushing, but NOT the Rear Stay Bushing yet. Once I have a chance to get under the car to locate both Stay bushing I will decide if I can handle the swap or if it needs to go to the dealer. They are not needed, but from what I have read they fine tune the shifting just that last little bit. Since our XVs are so new the OEM bushings will work well and most will not notice the ever so slight amount of play still left that I want to refine to perfection. Subaru also offers the replacement bushings in their STI line-up of SPT parts, so if you want your local dealer to price it out just give them a call. I have no clue which one is "better", they both look the same.
The only two companies that I researched were TWM and Kartboy. I went with TWM because it is one solid piece, so for me the quality in craftsmanship is greater. TWM also adjusted the throw forward with the arch in the top half of the shifter arm. Kartboy seems to be the most used short shifter because it is HALF the price of the TWM. It maintain the stock straight angles, but raises the center linkage mount to shorten the throw. The one quality of the Kartboy that I was hesitant about is that the pieces are welded together, vs the TWM one solid piece.
The brand that you decide upon is price dependent. There are review, raves, and critics for all brands, so pick what works for you. We purchased what I felt the more superior short shifter is, many will disagree simply based on the price aspect.
Dan
#15 · (Edited)
No, they are the actual Shift Linkage Stay Bushings, not the sway bar bushings. Attached is a copy of the Subaru image. You can see the Front Stay bushing, but I have no clue where the Rear Stay Bushing installs. I have added the picture to the previous posting.
Dan
#18 ·
I am glad that it worked out and went smooth for you. Thank you for providing a before and after evaluation of the shifter, I was unable to do so since I never drove our XV with the factory shifter. Enjoy the new shift positioning.
#20 ·
My thanks also to "The Hulls" for a great DIY thread....
My TWM shifter arrived last week, just got to install it today. Dang, it took longer to get the weighted Type R knob lined up just right (I got it "Pattern 1" engraved.) than installing the shift lever.
He's right, you just have to take your time and take it easy with the various fascias when removing them. I'm a big fan of Prolong grease, so I just regreased the cup and joint on reinstallation.
Once it was all back together, I took it out to the base so I could put it up on a lift to swap out the front and rear stay bushings. It felt so much better, even with the stock bushings....
TWM does not list the front and rear stay bushings for the XV yet, but having a gut feeling that automakers are notoriously frugal, I had them send a set for an Impreza and I'd eat it if they didn't fit. Won't be the first time I've blown $70 on something....
Up on the lift, (God, I love working on NEW cars....) it was pretty apparent that my hunch was right. The front stay bushing sleeve is just above the crossmember at the rear of the transmission. There is enough room to get in there without removing the crossmember. A 12mm wrench removes the nut, take off the large washer, slide the front of the shift stay off the stud.
About 16" back, you'll see where the rear of the shift stay slips into the rear bushing. It's a little tight with the heat shield, but you can get in there without removing it. Carefully pull the stay forward to remove it from the rear bushing. (Watch out for sharp edges under there.) With a ratchet, long extension, u-joint and a 12mm socket, remove the 2 bolts from the stock bushing and remove the bushing. (It'll fall out when you get the bolts out.)
Grease the hole in the center of the TWM rear stay bushing, and install with the supplied longer bolts. The new bolts take a 14mm socket. Make sure you have it right side up. The hole in the center should be perpendicular to the ground, if it's pointing down at an angle, turn it over. Tight is good, you don't have to ape the bolts. Grasp the stay and push it back into the bushing. This takes a little more effort than pulling it out due to the new bushing being stiffer. You're done with the rear stay bushing.
At the front of the stay, take a medium sized flathead screwdriver and get under the bushing lip. Hold on to the stay with your other hand and pry the stock bushing out of the sleeve. It's pretty soft, and if you get it a little at a time, it will come out. It's one piece, so just take your time.
The TWM front stay bushings are two pieces, take one piece and grease the larger flat side, the circumference and the hole. Slip it over the stud. Did I mention grease? Polyurethane gets squeaky if you don't grease it....
Grasp the stay and slip the sleeve over the installed bushing. It's a fairly snug fit, make sure the sleeve is squared up on the bushing. Take the other bushing half, grease up the hole and the circumference, fit it onto the stud and press it into the sleeve. Now grease the larger flat side.
Reinstall the large washer (I always go "sharp" side out....) and the nut. Tighten to about 13 ft/lbs. (snug)
You're done. It took me longer to type this than the job did.
The stiffer bushings make a HUGE difference, but there is a caveat - you WILL hear your transmission more. There's a reason those stock bushings were so soft. Noise isolation. Me, I don't care. I like hearing my car do its thing....
Cost? When you look at the build of the TWM shift lever compared to the stock lever while you're swapping the pivot bushings into it from the stock one, you can have no doubt you've spent your money wisely. It's just quality all the way....
I'm one happy shifter now....:D
#22 ·
My apologies, it's been a while since I looked at this thread....
I'm definitely happy with the TWM shifter. It has made the car better (more fun, if you will) to drive. I've forgotten what the old throw felt like....
The TWM shifter just screams quality, and the install is super easy.
I started with their Type R knob, which is about the same weight as the stock knob. I ended up going with their heavier Desert Eagle knob, which has improved the throw even more.
#23 · (Edited)
We are at 17k miles and climbing. The TWM shifter without the optional replacement TWM bushings is truly comfortable. The pattern is forward oriented so you don't tap the arm rest in 2nd, 4th, or Reverse. We are waiting for a good summer sale from TWM with free shipping to get the last bushing.
Dan
Remember where you have been because it will help guide where you are going. -DSH
#25 ·
Replace the front and rear shifter bushings with polyurethane and it will make the shifter a dream. And yes it does make driving the 5 speed much more pleasurable. (Short shifter and bushings) While the XV is not a race car and your main goal will not be to fire off quicker shifts before the RPMs drop, It does shorten up the throws making it more precise and easy to get into gear and tell what gear your in.
#26 · (Edited)
XV Nutt which shifter did you install TWM or Kartboy ??
Troutbum
