Can the keyless entry be reprogrammed so it does not beep?
4.7K views 13 replies 8 participants last post by  Zap
I would like the lights to flash, but not hear the beep. Is this possible?
#3 ·
here's clearer instructions on ridding the beep:
while sitting in car with all doors shut hold down unlock button on driver's door.
insert and remove key from ignition six times under 10 senconds.
open and shut driver's door after doing the key thing under 10 seconds.
no more beep beep bee beep!
#12 ·
Section 3-79 is only for the Multi-Function Display, which the U.S. models don't have (Ref 3-42). With the key-less entry system there is no way to perform the ignition key trick either (Ref 2-26). The manual does say that a Subaru dealer can change setting, which appears to be the only recourse in this situation (Ref 2-26).
