2014 Crosstrek HVAC issues
4.2K views 7 replies 6 participants last post by  qudrcps
OK, so I have 2 separate issues with the HVAC in my 2014 Crosstrek.
1. The AC works and blows cold air but, after a while, the air coming out warms up. It will blow warm air for a while and usually it cools back down. This will go in cycles as I'm driving. Occasionally, it will stay warm and not cool back down. In that case, I usually press the button to turn the AC off for a minute or two and then turn it back on to make it work. Can recharging the refrigerant fix this or does it sound more like a compressor issue?
2. Unrelated to the first issue, the number 4 position of the climate control fan speed is not working all of a sudden. It would be finicky here and there (not working on speed 4) but switching back to 3 and then up to 4 again would usually make it work. Yesterday, it will not work on fan speed 4 setting at all. Does that sound like a bad fan speed switch? If so, can you replace just the fan speed switch or do you have to replace the entire climate control cluster?
Thanks in advance for your answers.
Dave G.
