1 - 15 of 15 Posts
I did likewise.
2018 Lifted 6-speed Crosstrek
Ive used Lamin-x for years on multiple cars. I did yellow soon after I got my Trek as well. Changes light output color AND helps prevent rock chips on the glass.
After having the yellow installed for almost 3 years, I peeled them off and changed over to the orange/amber ones to match the back lighting on my ditch lights.
Love it! Takes me back to sitting along the Quai de Valmy in Paris having a beer and seeing a 1975 Porsche 911 Targa with yellow headlights. Thanks for posting.
regards
'21 Subaru Crosstrek Sport
Lamin-X is so easy and cheap, and protects the lenses. Years ago on my E36 M3, the salt and sand used by Chicago winter plows just destroyed 3 expensive driving lamps. I wish I knew about Lamin-X films then... would have saved me a lot of time and money.
Honestly, I just dig the look.
If you want 20% off of your order, you can use my partner link to make the films even cheaper...
306255
I do stealth mode, i just change my bulb with yellow phillips one, bit since it comes with chrome cover to prevent glare, at a glance it still show like stock but once the light is on, it will be fully proper yellow fog light. Applied the same with my rear signal bulb
Can you share which bulb you used? I like that idea. LED?
The fog light is LED Philips Xtreme Ultinon LED Car Fog Light Bulbs H11 2700K but the signal light is philips silver vision wy21w/t20 non LED, since the turn signal usage is not continuous there is not much advantage of using led bulb.
Thanks for the coupon link!
1 - 15 of 15 Posts
