1 - 13 of 13 Posts
Hello everyone,
I purchased my new XV Hybrid in late March and since then I’ve only reached an average of 27 mpg (mostly city driving) each time I fill up with gas. I’ve noticed other owners experiencing 30+ mpg but for some reason I cannot get there. Granted, they say you should you not worry about your gas mileage until after your break-in period of 1,000 miles and I only have 600 but it does make me wonder what I should expect going forward.
The one thing I have noticed after I purchased the car, is when I took it home and gave it a once over I noticed the tire pressure to be 42 psi in each of the tires. I looked in the manual and noticed the front should be 32 and the rear to be 30 so I let out the air to meet the manufacture’s requirement.
I’m wondering if the reason some folks are getting better gas mileage is due to those folks having 40+ psi in their tires. For those of you getting expected mileage could you report what psi is in your tires?
Welcome aboard. I do not recommend running tires at 42 psi. It would make your ride extremely harsh plus you could wear out the center portion of your tire for being over inflated. Go with the 32 & 30. Most engines need at least 3000 miles to loosen up. The warmer weather will also increase your mileage.
They often ship them out with overinflated tires, your dealer should have set the pressure properly as normal setup. I got mine around the same time and am averaging 28.8mpg with mostly city driving. Your driving habits are a big factor so be mindful of them. MPG will get better with summer gas and continuing break in.
My dealer had 40 psi on my tires when I picked up my car too! I don't get it at all...
I took it down to the 32/30 recommended pressure and since I've had the car I'm at 28.8 mpg. But with the latest fillups over the past month, I've been above 30. So I think you're right that after break-in you'll notice a little boost but the most impactful thing is how you drive and avoiding big hills, drastic acceleration/braking, etc. If you can keep it in electric mode during bumper-to-bumper traffic or going downhill, you'll notice a huge boost.
Hey you got the same one I do! A 2014 XV Crosstrek Hybrid Touring, Ice Silver Metallic. I just put some chrome fog light covers on and they look sharp. I prefer the silver over the green and with the silver rear led tailights it looks better.
PS I put in blue lighting too cause it ties in with the dash display and blue is more "electric"
PPS To make this more on topic I checked my tire pressure and it was high too so the moral is to check your pressure as soon as you get it home and often thereafter.
Thats pretty bad for a hybrid. My standard XV is averaging 30mpg mostly city, some highway.
Check your tire pressure in the cold. Then make sure your tire pressure is at least 32psi. If you are dropping the tire pressure to 32 after the car has been driven a little, its most likely that the cold pressure rating is probably around 28 or so. I keep mine at 36psi cold. I get the best mpg from that spec.
Checked my tires over the weekend and they were in 40-42 PSI. Brought it down to 34/32 (like to give a little extra to account for temperature drops). Instant ride improvement. Didn't seem to affect mpg.
Looks like that's a standard for Hybrids out of the factory. Probably to account for different climatic conditions and possible long dealer storage. It would be nice if dealers would adjust the tire pressure to recommended when delivering a new car though...
Our 14 Outback was at 42 psi all around from the dealer. Our 14 Crosstrek was 46 (ish) psi. I lowered them both when I discovered it. Funny part is, I took the Outback in for an oil change and they were back at 40+ when I got it back. I had a stern talking with the service manager, and told them to leave their paws off my pressures. I'm not sure why they are doing that.
My guess would be, they are trying to prevent accidental tire under inflation. By that I mean, owner who forget to check their tire pressure regularly.
when i put 40lbs in mine the lite comes on the dash as overinflated.max i can put in without the lite coming on is 38lbs
I raised mine to 44 PSI and see no discernible difference in "ride" from when the dealer had them at which is 35 PSI or so, can't remember, but anyway, i ran my Prius for 10 years at 40+ psi generally at 44 and consistently beat gas mileage figures. I have never had a tire dealer say that my tires were wearing improperly or anything. Physics will tell you that the ride will be stiffer but hell it's a CrossTrek not a Caddy anyway :) I can't tell the difference in ride but i can in gas mileage, and they are ready for 51 psi cold so 44 isn't that bad.
Hello everyone,
I agree fully with dstmark. I had run 4 seasons tires at their maximum cold pressure for their lifetime (actually I increased their lifetime...) with the two side effect being: a harsher ride and better fuel economy.
The type of tire you have on will also make a difference. A sticky rubber versus a eco friendly tire won't get you the same fuel economy.
I have a 5 speed manual, no option XV. I got my best tank of 30.4 US mpg (7.729l\100 km) with my new Continentals True Contact inflated at 40 psi all around.
I filled up and put 5 more psi in them for 45 psi for this tank.
So far, this tank will be even better than the 40 psi one (I knew that...).
I drive mainly on the highway at night, so I can go a little bit slower.
I'll keep the tires at 45 psi for a little while before bumping them to 51psi because the temperature here will go up, so fuel economy.
I wouldn't do that with anything in the tires other than Nitrogen gas....Air will expand greatly beyond your 44 to 51 psi..But hey it's your car....
1 - 13 of 13 Posts
