1 - 4 of 4 Posts
my 2016 front rotor 23.5mm, rear rotor 9.6mm.do i need replace rotor?what is minimum front rear rotors?
Unless you had your rotors machined, chances are you aren't even close to the wear limit which by the way is 22mm for the fronts (factory comes with 24mm BTW) and 8.5mm in the rear (factory is 10mm).
1 - 4 of 4 Posts
