Found our driver's side(both, upper and lower) solenoids leaking when I got under the car the other week to do a coolant/t-stat service. This morning I got out there and changed them out. 2 10mm bolts holding each in. The clip that holds the electrical harness on is mildly snug in there. Parts ordered for a MY18 premium/wt cvt:
1) Vvt solenoid pt # 10921AA231
2) o-ring seal pt # 806944060
3) plastic ring pt # 16677AA040
The o-ring seal didn't seem to be the main cause for the leak, it was coming from the switch housing itself. It's a fairly easy DIY on this engine. The fact, one of our local dealers carries 12 of the o-rings in stock, says they are replacing them like mad. Afterwards, engine runs better with less noise. If I had to take a guess, the old recalled plastic pcv had broken apart and some bits made it to the solenoids.
Sorry for the poor pic, camera had wrong lens on it.
Hope this helps some others out there.
Regards
Regards
