1 - 8 of 8 Posts
2021 premium 6MT
I know that Subaru has a lot of wiring that’s preexisting like the trailer hitch and for the fog light kit they sell all just plug and play. I have a ‘21 premium it has the cig lighter in the center console but no usb. Does anyone know if the wiring for the usb is there. There is just a cover in place of where the usb should be on higher trim models. Was wondering if I could just get the factory USB ports from a junk yard or online and plug them right in?
I thought that after '18 they moved the USB to the cubby under the HU? I suspect that was to reduce the overall cable length. Are you referring to the armrest cubby?
Got it. Our '18 Limited has two USB ports in the armrest cubby and since day one I've had a USB C cable and a Lightning cable plugged in there. I have a Google Pixel (Android) and OtherAstroKat has an iPhone. They always work, except that if I am using Android Auto to navigate and she plugs in her iPhone to charge it will take over, so there's a priority issue. We now have a cig port adaptor for that.
Just run a cable. It's easy to slip it under the side of the center console without pulling anything apart.
There have been some issues with certain brands of phones (e.g. Samsung Galaxy) and AA. I had an original Samsung Note but my last three have been Pixels - assuming that Google's version of Android is about as pure Android as you can get.
As Astrokats wrote, the cubby under the HU for music and data.
Reactions: AstroKats
2021 premium 6MT
Discussion Starter · #7 ·
I’m just looking for charging power, I was curious if anyone has either installed an OEM set of subs or has been under the arm rest to see if the wiring was there
It's just a USB cable. I can't say for certain because I haven't pulled the center console apart (yet) but that's all you need, and I doubt there's anything there after they moved it. If it's only for charging I'd recommend a cig port adaptor. Our Limited has a cig port in the armrest cubby.
Thanks @CRAZYHAWK I wasn't sure when that happened...
Reactions: subyrubyroo
1 - 8 of 8 Posts
