Unknown noise
32 reading
165 views 8 replies 4 participants last post by  TotalChaos71
22 Sport. So, I normally pull down my street, and when I approach my driveway, turn hard to the left and brake, with the rear of the car lined up with my driveway, as I always back down the driveway. Lately when I am almost stopped, with the wheel turned hard to the left, I get a strange light "crunching" noise. Its not too rough, but noticeable. Sounds like its coming from the left front. This seems to be the only time I get this noise. Any suggestions where to start looking? Suspension, Wheel bearings, CV joints?
#3 ·
Probably the CV joint. Not an uncommon issue on any vehicle that has CV Jointed axles.
Suspension issues typically happen when you hit a bump and you would hear it with normal driving.
Wheel bearings you would hear with normal driving or going around a turn.
that being said, having a good look with a flashlight is never a bad thing. See if there is an oozing from bushings. If the CV boot is torn, rust near any suspension part. Sway bar links are also a possible culprit. Step one is just get down there and look. Post pictures here of anything you are not sure about. Be sure to have a good look at all the steering linkage too. These can also wear over time.
#6 ·
My initial thought was the CV joints, didn't think about sway bar links. No noise when driving so that threw me off. I am planning on digging around underneath this weekend, but you've given me food for thought. Thx!
