Subaru OEM oil is SN rated, it has no LSPI protection whatsoever. This is what it had from factory and at first oil change. I also do not recall clearly if previous oil changes made any effect on knocking or make it disappear for a while. It is my pleasure to keep an eye on new SP rated oil. I got used EGR valve from ebay, it cost peanuts. I would not even bother with dealer, just not worse my time. I could change it at will though, if it is an issue. BTW, in my entire life I never had an issue with EGR valves in any vehicle.
Not sure why we need any clarification of the LSPI issue - the industry adopted SN Plus and SP specifications just to deal with this issue alone. It was serious matter for them and manufacturers.
BTW, Subaru could change ECU to avoid it all together, but it will effect efficiency/emission as they need to keep engine at higher RPMs or keep EGR at low level in this situation. Subaru should not sit on this for long as it will be bigger problem when they need to change engines as a result of LSPI. The symptoms are LSPI, what triggers it is another story.
