1 - 11 of 11 Posts
I know nothing about trailer hitches except that the Crosstrek has a maximum towing capacity of 2000 lb
Does any size fit? Any recommendations?
Thanks
A good place to start is to know what you are going to use the hitch for. They make 1.25" and 2" receiver sizes and different classes. I go off road so I use mine as a bumper guard and to carry a basket for a cooler when I go to the lake.
It takes a little modifying of the frame during install but by myself it took less than an hour. I didn't need to remove the exhaust, I just worked around it. Youtube has some good videos showing how to install.
2020 Pearl White Crosstrek Sport with Eyesight, CVT
There is another full discussion re trailer hitches and the pros and cons of each brand.
I went with a Subaru dealer installed one (pricey) because it was installed correctly so in a rear end collision, the crumpling effect is accomplished on the car and not on the humans inside, an important consideration for me.
I remember that debate. Aftermarket hitches didn’t exist for a months after I got my 18’ and I needed it before winter so I got the OEM, delivery installed. I would have gone with an aftermarket and DIY’d the install if it was available but I stand by my OEM and since found knowledge of the crumple zones and trailer hitch rear enders.
Thanks
I don’t really want to revive the hitch capacity discussion but in Europe, they tow up to 3,086 lbs while here in North America, the towing capacity is:
1,500 lbs with trailer brakes; and
1,000 lbs without trailer brakes.
Most fascinating being that the Euro Crossies are equipped with the 1.6 liter flat.
Lol; yeah, we know. I sum it up as a north American legislative limitation which I guess has to do with the geographical and environmental differences between Europe and here.
Except for certain areas, it's comparatively flat and mild in Europe but I'd still rather haul a trailer up an Alpine road than a Rocky Mountain road; less asphalt rot, potholes and moose.
For transparency, I haven't looked up towing capacities for other regions.
I put a Curt hitch on my'16. They make one that goes on pretty easily. If I remember, two of the mounting holes in the Crosstrek needed to be enlarged by a hair to get it to fit. I was able to install it in about an hour - nice solid hitch.
I have a 2018 Limited, and I highly recommend the Stealth Hitch. It solves the issues of interfering with the car’s crumple zones, and is just a much nicer installation all together. It’s pricey, but the quality is top notch. I use it primarily for my 2” Yakima bike rack, and it is perfect for that application. I also have the adaptor for a trailer, and it works well. The link is for the pictures I posted of my install. Model Year 2018 and Newer - Looking for a recommendation hitch + bike rack.
Subaru Crosstrek Hitch (2018-Present)
Sent from my iPad using Tapatalk
Still liking the eco hitch I put on my 14 XV. No one knows it is there unless I remove its little hatch. 2in receiver better for bike rack. Never on top
1 - 11 of 11 Posts
