Thank you muchlyI am digging the accents you put in. I have the same inserts to accent the orange stitching. The rings around the climate controls work well.
Being the scifi nerd that I am, I really like the TR-8R name.![]()
Most of the pads that go up there - if you live in a warmer climate - tend to heat up too much and bleed out chemicals which will stain the upper dash area. Also some of the cheaper pads will shrink and distort after extended sun exposure, and look like crap. I was going to get a pad for there, but decided not to. YMMVThey also make a pad with the orange accent that fits on the upper dash. I put one in our Trek. I like it because it keeps things clean and allows you to lay something there without having it slide around.
Thanks for the info. I'll keep an eye on it. It's my wife's car and it is garaged so it might not be an issue.Most of the pads that go up there - if you live in a warmer climate - tend to heat up too much and bleed out chemicals which will stain the upper dash area. Also some of the cheaper pads will shrink and distort after extended sun exposure, and look like crap. I was going to get a pad for there, but decided not to. YMMV
