1 - 5 of 5 Posts
Ok. I tried searching in the forum but didn't find an answer, so I guess I'll have to ask.
This is my 1st Subaru, I'm coming from a Wrangler. When I switched rims and tires in my Jeep I had Discount put in new TPMS Sensors and did not have them program them or anything, they learned themselves or something.
So my question is this: when I go to buy another set of rims and tires I want to keep the stock set for winter usage and use the aftermarkets for summer. How is that going to work with the TPMS Sensors? Will I be able to just switch sets whenever I want and the car will pick up the new sensors? Or do I need to bring to a shop every time I switch wheels and have somethi g programmed?
Thanks in advance for your answers!
Sent from my SM-G996U using Tapatalk
Discussion Starter · #2 ·
Sorry, forgot to add that it's a 2021 X-Trek Sport
I run two sets of wheels, one set for summer and one set for winter. I bought my second set from Tirerack and ordered them with Autel Programmable Sensors.
I then bought the tool to be able to clone the stock ones to the new Autel ones. Once you do this you can swap tires whenever you want to w/o having to worry about it.
You may have a local tire place willing to clone them for you for a limited charge. This would keep you from having to buy the tool.
Discussion Starter · #4 ·
Thanks! I'll have to look into that once I get the money for a new set of wheels and tires. Hopefully it'll be before spring
2019 Crosstrek Limited
If you have Discount Tire wheels and tires, they should (at least mine does) come with lifetime winter/summer wheel swaps and TPMS setting. That's one of the reasons I went with DS.
1 - 5 of 5 Posts
