1 - 3 of 3 Posts
Anyone install the Torklift Ecohitch and Wilco Hitchgate Solo on a 12'-17' model?
I just finished installing it on a 2016 Hybrid Model. Noticed that it rubs up on the bumper, anyone has the same issue?
Wondering if I had to push it all the way forward.
I Was unable to install the Wobble free piece of the Solo Hitchgate. How did you guys work around this? Did you install a non Wilco option like this one or another option works better.:
https://www.amazon.com/HiTow-Tightener-Anti-Rattle-Stabilizer-Rubber-Coated/dp/B077SHGWZM/ref=sr_1_10?keywords=wobble+free+hitch&qid=1560311148&s=gateway&sr=8-10
Also noticed that when I shake it bumps on the Muffler, anyone have this too? is this a potential issue?
Let me know your thoughts on this, I really want to know how people have dealt with this. Or if they just accept the bumper rubbing. Otherwise I might have to sell it and get the Curt Version, Not looking forward to the loss in departure angle with that.
I have the eco hitch installed on my 13. I bought a cargo carrier for back there and took it on a 500 mile trip and the wobble was horrible. Had me paranoid and scared it would eventually break off. I didn't install the anti wobble as i wanted to be able to remove the carrier easy and with the stabilizer it came with barely any room to get a good fit anyways since its sitting in the bumper skin. I emailed curt and they recommended a anti wobble that goes inside the tubing.
I haven't noticed any rubbing .
Which Attachment did you end using? When you installed the EcoHitch did you install it as far back as possible?
Please let me know your thoughts on this.
I am currently using a 12" hitch extension, it doesn't wobble just jumps up and down during hard bumps. I was able to attach insert the Wilco Wobble attachment into the extension so it doesn't go side to side, more stiff. Problem is it makes it heavier as it increases the tongue weight. Also adds some slight humming at times. I have a feeling it will hum more once I install it without the extension.
I am thinking of removing it and using two wobble free attachments like this one:
https://smile.amazon.com/dp/B0141SI2HY/ref=cm_sw_em_r_mt_dp_U_Yg4iDb1R5E7P6
https://smile.amazon.com/dp/B001EOWR3Y/ref=cm_sw_r_tw_dp_U_x_Zh4iDb69DHJ1E
1 - 3 of 3 Posts
