Some of us remember cars that had a manual choke.
It would do the same without all the computers fuel injectors.
Yes, I remember that carb cars would idle really fast when you first started them. That's because when you depressed the gas before starting, that would close the choke completely. Once the car started, the choke would open just slightly. Tap the gas then and the cam would drop to the next step which would bring the idle down a notch. Otherwise like you said, the car would buck like an angry horse.True, but with carbureted engines I would NEVER shift it from park to reverse/drive while it was still on high idle. I have a car with a '73 Pontiac motor and you pump it once and turn it over. It starts on high idle and you simply blip the gas pedal and it goes off of high idle and now you can shift it out of park. If I were to shift it out of park while still on high idle it will chirp the tires when going into gear (and you better have your foot hard on the brake pedal as well). Not good for the driveline.
I know today's cars have torque management built into the ECU programming to keep things like that from happening, but it's still hard for me to shift into gear at high idle. My Subaru is the first late model vehicle I've had that has such a pronounced high idle when cold.
Ha! I remember the original Honda Civics and Accords back in the mid-1970's had a 3 bbl carb with two manual chokes.Some of us remember cars that had a manual choke.It would do the same without all the computers fuel injectors.
The early Jag V12s had four Strombergs. That was fun...Ha! I remember the original Honda Civics and Accords back in the mid-1970's had a 3 bbl carb with two manual chokes.
What on earth does being a college student have to do with it?Ideally, this is what I do. But, I'm a college student and that extra 3-8 minutes can really cost me sometimes.
Or you could just adjust the high idle down a bit on the carb car. Normally its a 1000-1500 judt like injected carsTrue, but with carbureted engines I would NEVER shift it from park to reverse/drive while it was still on high idle. I have a car with a '73 Pontiac motor and you pump it once and turn it over. It starts on high idle and you simply blip the gas pedal and it goes off of high idle and now you can shift it out of park. If I were to shift it out of park while still on high idle it will chirp the tires when going into gear (and you better have your foot hard on the brake pedal as well). Not good for the driveline.
Trouble is if you make the fast idle lower before you bump it down, it will be too slow after you bump it down and may stall.Or you could just adjust the high idle down a bit on the carb car. Normally its a 1000-1500 judt like injected cars
College students are always running late?What on earth does being a college student have to do with it?
Not just college students, LOL!College students are always running late?
SHMBO runs on her own time.Not just college students, LOL!
Me three, LOL!SHMBO runs on her own time.
I have learned over the years to add in 15-20 minutes to any appointment time- and keep it to myself.
I remember it like it is today. Oh yeah, it is today 'cause my '76 Toyota has a manual choke. Did some chokin' just this last weekend.Some of us remember cars that had a manual choke.It would do the same without all the computers fuel injectors.
Yep, if the blue light means you can't drive the car then they would be pretty clear about that in the manual. Similar situation here, by the time I've started the car, plugged in my phone, put on my seatbelt, opened the garage gate and got to the end of the alley, it's out.Mostly B but by the time my electric sliding gate's open and I put it in gear probably D. I do not believe there is any need to wait for the blue light to go off. (or wait until it's at operating temperature) Unless you're prone to step hard on the gas and demand she revs hard, in which case I suggest you Do wait for engine to reach operating temperature. As it is the oils are soo thin even at low temperature there's no need to wait, ordinarily.
Exactly. I start the car, back out of the garage, close the garage door, put on my seatbelt. By that time, at least a minute or two has passed. Blue light is still on at that point, but I just drive gently until the light goes out. Only time I wait longer is if it's REALLY cold, then I wait at least 3 minutes from start-up as per the car's "time elapsed" indication...........by the time I've started the car, plugged in my phone, put on my seatbelt, opened the garage gate and got to the end of the alley, it's out.
Well driving does warm the car faster than idling. That means less time you're running a rich fuel mixture. Though unless your commute is only 5 miles, I find this dramatic a difference surprising. After all, the difference in warm up time would be 2-3 minutes at most.I know this will come as no surprise. Since I've been treating it like a normal vehicle and not letting it idle till the blue light goes off, my fuel economy has increased by a decent amount. I have 230 miles on this tank now and I'm averaging 31.2mpg (according to the car, so I know it's less), using it for my daily commutes. Before I was seeing mid to high 20's by way of the car's display.
