21 - 33 of 33 Posts
Discussion Starter · #22 ·
One would have to check whether the car is pre-wired for it, and whether the harness provides the signal. There are instructions online for the removal of the AGS on a Legacy, I would presume the design for the Impreza is similar. The diagram also points out to a temperature sensor.
Subaru Legacy Service Manual - Removal - Active grille shutter (sulegacy.com)
Thank you for the link. Now I know there is a wire on each side. I thought it was a 4 wires connector/harness on one side only. Thanks again.
Even if the wiring is there it will have to be activated in the ECU. It likely is not turned on for cars that do not have it or you would get an error code for the missing shudders.
Discussion Starter · #24 ·
Thank you for your advice. Like your said, just because it is there, it does not mean it is ready to use. Otherwise, it would be like the fog light, it would be an option for dealer install.
However, I have been lucky with several non-option add-ons. with our old old Honda and prior Subarus. So, if the harness/plug is there, I am going to give it a try. I really hate the cvt not shifting to higher ratio in winter issue. If it does not work, I will get a acrylic board and block off the lower intake during the winter.
First that I heard about this so I went and had a look at our's and guess what...woo hoo....it has it - so on the UK model (which come direct from Japan). Having said all that I struggle to see the benefit on such a car
Subaru XV 2021 2.0i-S (Aust)
Sorry, not meaning to question you but you have an actual shutter across the front vents blocking it at times, not just the sensor as in the pic? The OPs pics are a little hard to follow because they are both upside down.
Think so, when the car is started it opens and closes, has two pieces on each side of centre
Discussion Starter · #32 ·
Very sorry about picture being upside down.
21 - 33 of 33 Posts
