1 - 20 of 46 Posts
Site Sponsor
SL1 LED Headlight Bulb for 2016-2019 Subaru Crosstrek
Diode Dynamics is pleased to offer the USA-made SL1 LED Headlight Bulbs for 2016-2019 Subaru Crosstrek
SL1 LED Headlight. If you're looking to improve your 2016-2019 Subaru Crosstrek's visibility at night, you've probably seen plenty of aftermarket LED headlight bulb options. There are plenty of “high performance” LED lights on the market, but they all have their shortcomings. They're too big to install, have no hotspot in the beam pattern, or they simply stop working after just a few months! With its compact size, optically correct output, thermally-modeled cooling, and boost-mode electrical circuit, Diode Dynamics SL1 LED Headlight Bulbs are truly the best LED headlight bulbs on the market.
Street Legal Output. Don't be fooled by high lumen numbers or "projector specific" bulbs. Your 2016-2019 Crosstrek's headlights are designed to focus light. If the light source is out of focus, it doesn't matter how bright it is - you won't have a focused hotspot of light to shine down the road - just more glare. Some generic options have such a poor optical design, they might leave you wondering “how are LED headlights legal?!”
To correct this, the Diode Dynamics' SL1 LED Headlight Bulb was engineered with advanced optical design software, to perfectly match the halogen filament location. This allows the SL1 to focus light just like the original halogen headlights, preserving the focus and hotspot, with no added glare. It produces a functional beam pattern with zero glare, which we call Street Legal.
Tested to Perform. We test the SL1 in factory car headlights and measure the entire beam pattern using specialized equipment. The entire beam pattern is mapped, and we compare the total output to the original equipment, confirming that the SL1 headlight bulb shines more light in the hotspot, without adding extra glare on the road. The test results speak for themselves: in most lamps, like the 2015 F-150 halogen lamp below, there is 30-70% more light output in the critical hotspot, with zero glare. Thanks to optical engineering, testing, and validation in the application, the SL1 is the #1 LED bulb for reflector and projector headlights.
Staying Cool. You might’ve seen led headlight kits that use large straps for cooling, or fans that just make noise. These light bulbs run hot, resulting in degradation of output after a few months. When it comes to cooling, proper engineering is required to efficiently remove heat from the bulb. In the SL1, a copper core board, thermal phase-change material, and thermally-modeled zinc casting get heat to the base, where base fins release it, designed for aerodynamic performance in conjunction with the flow rate and pressure of the Sunon bearingless micro fan. The result is a highly effective and reliable cooling system, keeping the SL1’s LED chips running at maximum potential.
Fitment. With its patented design, installing the SL1 LED headlight bulb is simple and straightforward, requiring NO cutting or modification. There's no hanging metal straps, just a compact bulb that plugs right into your 2016-2019 Subaru Crosstrek, with a nylon-reinforced shroud. Only slightly larger than a standard halogen bulb, it fits behind dust caps and in tight spaces. The base sizes are keyed specifically to fit your vehicle, not one-size-fits-all! And the compact driver easily tucks away.
Reliability. Every part of the Diode Dynamics' SL1 LED Headlight Bulb is engineered with more expensive OEM-grade features to assure quality, such as the Sunon MagLev fan and PCB wire connectors" In short, these are designed, tested, and built to a much higher standard than your average imported led headlight conversion kit. The Diode Dynamics' SL1 LED Headlight Bulb will keep performing in your 2016-2019 Subaru Crosstrek for years, and is backed by a three-year warranty.
Specifications
Measured Lumens: 1630 (per bulb)
Color Temp: 5700K (cool white)
Power (watts): 20.2
Operating Voltage: 5-16V
Current (amps @ 13.2V): 1.58 Polarity:
Polarity Specific LED Emitter: Luxeon Z ES
Connector(s): OEM-Size Plug and Play
Driver Features: External, Waterproof, Constant Current
Materials: Copper PCB, PP-TD30 Base, Zinc Heatsink
Cooling: Active, Mag-Lev Microfan
Compliance Ratings: FMVSS108 Beam Pattern, SAE J575 Durability Test
Click To Order Your 2016-2019 Subaru Crosstrek SL1 LED High Beam Bulb Replacements:
Diode Dynamics SL1 Low Beam LED Headlight for 2016-2019 Subaru Crosstrek
Diode Dynamics SL1 High Beam LED Headlight for 2016-2019 Subaru Crosstrek
If you have any questions, please don't hesitate to post, PM, email [email protected]
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Jake H.
Diode Dynamics
Site Sponsor
Discussion Starter #2
LED Focus: What you need to know!
Are you looking to make the switch from halogen to LED headlight bulbs? Before you do, check out this video to ensure you choose the best one.
Good optical focus means more light further down the road where you need without any glare. We put together this video to highlight what to look for when choosing an LED headlight bulb for your vehicle. Check it out! And don't forget to shoot us a PM for free USPS shipping on any U.S order!
Jake H.
Diode Dynamics
2020 Pure Red Crosstrek 6-spd, 2019 DGM Crosstrek 6-spd
There’s a new member here named car-a-holic. He PM’ed me asking about the free shipping, but since he’s new I can’t respond to him directly. Perhaps you can look him up and explain how that works.
BTW, I missed the free shipping deal myself as my order arrived last Friday (5/17). The SL-1 low beams are amazing, and the marker LED’s add a nice touch.
from one Jake to another, thanks.
Jake
Site Sponsor
Jake
Sure thing! I'll see if I can reach out.
And feel free to shoot me your order # in a PM. Assuming it qualifies (USPS shipping + U.S address), I'd be happy to get those shipping costs back to you.
Thanks!
Jake H.
Diode Dynamics
Site Sponsor
These look pretty legit for halogen diffused housing. If replacing both H11 and 9005, does the 9005 (high beam) reduce voltage to accommodate DRL? Have there been problems with using your 9005 as DRL? TIA!
Thank you!
And that's a great question. Because the SL1 requires so little power, it actually remains at full brightness when serving as a DRL.
Aside from the additional light output, we've had no reported issues!
Jake H.
Diode Dynamics
Site Sponsor
Discussion Starter #7
Think having LED headlight bulbs shine light 360-degrees is a good idea? Think again! Check out this video to see why!*
Jake H.
Diode Dynamics
Jake, a question if I may,
i just installed your SL-1’s on my 2019 Premium. They work great, but after seeing this vid I’m not sure I did the correct alignment. On page 2 step 3 of your installation guide you state that the light should shine in opposite directions vertically from the bulb. Your video gives me the impression that the LED’s should fire sideways. I had to rotate the collar to align the LED’s up and down ( I even mentioned this in my PM to you, and you said the fans will work in any orientation). Opposite directions vertically I interpret as 12 o’clock and 6 o’clock, not 9 and 3.
Please clarify which orientation is correct.
Thanks in advance.
Jake
Site Sponsor
Discussion Starter #9
Thanks in advance.
Jake
Hi Jake,
I apologize for any confusion, it's possible I misinterpreted your initial message. In the housing, you want the LED chips facing to either side. In some applications, this requires rotating the collar, which in turn rotates the fan. The position of the fan doesn't actually matter, it's the position of the LED chips themselves that will impact output.
Hope this helps!
Jake H.
Diode Dynamics
2017 Crosstrek Limited
Having mine professionally installed tomorrow afternoon. Will report back on my impressions.
Hi Jake,
Hope this helps!
Jake H.
Diode Dynamics
Thank you for the correct procedure. I just copied this from your online installation guide:
3. Check to make sure the bulb is aligned vertically, and adjust rotationif necessary.Headlamp optical systems are designed to work with light that is shining in opposite directions, vertically from the bulb. Some vehicles have the original halogen bulb rotated at an angle. If the SL1 is tilted at an angle when installed, correct this by adjusting the rotating collar. See collar adjustment instructions on page 3.
Perhaps instead of saying the bulb should be aligned vertically you should state that the LED's should fire horizontally and the bulb housing should be aligned vertically. That's what threw me off. I thought it was funny that your literature states that this should be a plug in install without any adjustments and when I tried it it actually would have worked right out of the box, but knowing my luck with aftermarket parts (my motto is "one size fits nothing")and misinterpreting your instructions I now have to get the tiny screwdriver and realign the bulbs.
No biggie. You still have a quality product and it was just my readthrough that caused an issue.
Thanks for the correction.
Jake
Jake,
I just flipped them for horizontal firing and BIG DIFFERENCE!
Thanks a lot!
Jake
When it got dark here I thought I needed to take a drive to try out the new LED's. So just because I had to report back I decided to drive to the closest ice cream shop for a hot fudge sundae. Might as well :) Happy ro report the new LED headlights are great for a retrofit. They are focused, well aimed, bright, no flicker or interference with any electrical or radio functions of the vehicle.
Reactions: lightbg
Oh and let me add that the customer service Diode Dionamics and Jake gives us, and I assume all customers, is excellent. :wavetowel2:
Site Sponsor
Discussion Starter #17
Thanks for the shout-out! And in turn, the Subaru community has been extremely supportive of our company over the years.
Thanks!
Jake H.
Diode Dynamics
Site Sponsor
Discussion Starter #18 (Edited)
How hot an LED headlight bulb gets has a BIG impact on how bright it will be over time and how long it will last. Check out this video to see if your headlights are getting too hot!​
1 - 20 of 46 Posts
