1 - 5 of 5 Posts
Hi All, after months of planning and reading ALOT of forum posts here and over at SFF and NASIOC I finally wired up my new JDM folding Mirrors with Side View Camera and wired it to the Upper MFD Screen. I'll post as many pics and info as I can and did collect but it may be basic.
Mirror Set from
Mirror Fold Switch
Is it worth the cost?? Yep I love it but depends on your Budget this was total of $1000 AU for mirrors switch and Postage to Australia
The mirrors come with Folding, Turn Signals outer and inner, Puddle Lights, Heaters and Collision Alert wires and features.
297667
297668
297669
ALTHOUGH I did order MY17 WRX mirrors they are SLIGHTLY smaller than Original XV mirrors ..........oooooops
They come with Silver mirror Covers which I prefer now and this seems to be something appearing on the WRX and Levorg in the MY18+ releases
Like Rlouie said here in a previous thread on his Folding Mirror Project the JDMs come in 12 PIN plug Format and you are gonna have to DEPIN them down to the 10 PIN version and retain the original mirror Connector for this ( I could not find new ones Online anywhere) So I had extra wires for SVC and Puddle Lights, Heaters and Collision Alert
12 PIN JDM's
297670
297671
Original 10 PIN with Mirror Adjust wires ( Blue Pink Purple) and Green White for Turn Signals
297672
297673
Mirrors and turn Signals where all Pre Wired and a simple match them to original position
BUT
Wiring up the Side View Camera took a bit of work, mainly because I had to guess the wiring pin set up in the MFD based on a few Threads here and on the NASOIC and Forrester Forums on Rear View Camera Set ups....... but got it to work based on the 4 wires on the SVC ( Yellow Brown Red and Black)
297674
297676
Red and Black on the top pins 3-4
Yellow and Brown on the bottom pins 5-6
I can only post 10 pics so I'll sign off here and post a follow up as I have more Pics and info to share
Discussion Starter #2
I must admit threading wires up to the MFD wasn't too hard just a PITA but if you are patient you will be OK. Youtube is amazing for instructions on various trim removal and other info. "Gotta love it" !!!!
Next I wired up the Folding Feature and here THANK the Gods for Factory Pre Wiring YES
297679
297678
Brown and Grey ( just 2 wires for the Fold feature under the Green and White Turn signal wires) NO extra runs of wire for AU market it seems?
Im still yet to wire up my Puddles and the the Heaters I'm a bit confused on this as I read on here and elsewhere that I can tap into Harness up on the A pillar for Puddles (Yellow and Black & Light green or teal? and Black wires for Puddles)
The heaters are dual Black wires (and there is only one spare black wire left after all accounted for)..........on the back of the mirror glass element and Im a bit stumped for now. I read somewhere that these are double Ground???
Pics of SVC working after much wiring and pin Confusion
ALTHOUGH
I will put up with reverse Cam Guide lines instead of that cool WRX side View Guide line.... I'll need to upgrade MFD for that.........hmmmmmmmmm,
also the reverse gear is activating the SVC I'd love to be able to push the Enter Button for extra access like on the WRX
297680
297681
Well I'll post more as I go, I gotta get those Puddles sorted and LATER LATER on Im gonna try the after market Collision Kits from AliXpress and use those Mirror icons
More soon
Hi, I realise in my original post I mention for the SVC wiring set up in the rear 8 PIN PLUG for the MFD I mentioned Red and black wires on the top and yellow brown on the bottom pins........
WRONG
That pic is actually flipped, So its red and black on the two bottom right side pins and Yellow and Brown wires for the two top left side pins, I'm an idiot... I'm very sorry!
and to add to the frustration the system on this Forum wont allow me to edit a post and need one of the Mods to do it for me.
So to clarify the pic is the rear view of the MFD and the 8 pin is the empty slot over to the right side viewing the rear of the MFD from the back side.
that label you can see is stuck on upside down at the factory, just to clarity pic orientation. So for the correct operation it should look like this for Side or Front or Rear View Camera (assuming this would all be the same for any camera input)?
I said I have to put up with rear view camera overlay until I get myself a WRX MFD with built in SVC overlays and View/Return Toggle (enter button) this allows for momentary activation of SVC at any time, although the reverse action is ok for the time being. Im about to make it look all profesh with the 8 pin comnectors I bought in from AE.
298308
298309
Im attempting to wire in the Auto Mirror Fold/Close Module I got from AE and is proving difficult as Im not any real Auto Electrician and the destructions are a bit hard to comprehend
more soon
Well I tried the auto close module but have run into some issues so have left it for now, mainly Chinese to english translation and dodgy adds in Online stores, it maybe also that these are made for LHD and are not clear about that fact for RHD markets. I idid manage to purchase a MY17 WRX MFD that belongs to a Car that had the SVM system in the older two screen version ( not a MY18 Single screen MFD) and all went Ok with install (the easy part) but sadly I still got the Rear View Camera Ovlerlays and not the SVM overlays. The enter button does not activate the SVM upon request like the factory system, It must be something to do with internal CAN Programing and not Firmware in the MFD itself, I really thought this was the answer. So for the sake of a boost quage I now havea complete MFD and leather red stitched hood for sale obver in the For Sale section. Anyone got any insight on the 8 pin plug on the back of the MFD?? is it that I may need to select different pins other than the ones I have the 4 wires connected to? could it be that sim0le? I relaise in USDM that SVM isnt a feature yet? so the Zero interest here is understandable.
Cheers for reading anyway, I'll update here as i move along with my various projects, but my foldin gmirrors are working great and the basic aspect of the SVM is also working in the reverse gear mode.
1 - 5 of 5 Posts
