As I mentioned in my new member introduction, this was something I was waiting on parts for. I really liked the shift trim and boot in the Limited model so I was looking up part numbers to see if it would be a simple swap. The actual base with the switches and cupholders is the same part in both the Premium and Limited, so common sense told me the swap would be possible. Ordered the shift indicator (which is the name of the trim piece) and the boot. They came in today and within 10 minutes of getting home from work everything was disassembled. The wire that connects to the bottom of the shift indicator has a different connector, and different wires, so I have that wire harness coming. Probably has to do with the fact that the letters light up individually on the new shift indicator. The wire harness w/boot shares the same part number as the harness w/o boot, so who knows if it works and I'm not going to be mad if it doesn't. I'll keep you updated. If anyone wants more details on this let me know and I'll try to make a walk through when the harness gets here.
