Hey Friends, I splurged; let me know if you're in the area and want to come borrow.
Clarification - Under System Setup in the TS508 tool, feature number 10 is "TPS Prog Limit". If this feature is set to "Off", you can clone or program Autel MX sensors already mounted in wheels with tires pressured up. If the "TPS Prog Limit" feature is set to "On", you will have to air down to <69Kpa or 10 psi.Yeah dude, let me know! They have to be aired down all the way to be cloned, so before you put them on the car give me a holler.
Oh dang that's good to know!! Thanks for the info!Clarification - Under System Setup in the TS508 tool, feature number 10 is "TPS Prog Limit". If this feature is set to "Off", you can clone or program Autel MX sensors already mounted in wheels with tires pressured up. If the "TPS Prog Limit" feature is set to "On", you will have to air down to <69Kpa
