The crosstrek is still a compromise car. It is a car chassis, that is lifted. So to give it a little bit more Road hugging competency, they equipped sway bars. Which is totally fine. 99% of Subaru owners never push their Subaru to the limit. More often than not, they are taking a trip to the grocery store on an inch of ice or snow. And the all-wheel-drive might only kick in when they leave a stop sign.
if they did not equip front and rear sway bars, then the car would yaw like a barge on asphalt corners. And that would be a reason to not buy the vehicle. If you look at a trophy truck you will see that they still have stabilizer bars. However, they are a much more different set up than what we have. All I was saying is that the people that want to upgrade to stiffer sway bars really need to analyze why. If you want a better handling Subaru, and then buy the Impreza which already has A lower ground clearance. If you want to do some serious offRoad activity, then just disconnect one side of an end link. This will allow the suspension to articulate more for off-road rock crawling, which I still do not condone doing. The drivetrain on the Subarus was never designed to crawl on the rocks. Oh, and I don’t know WTF is with the small font.
