I couldn't find the thread here but found this via Google: https://www.reddit.com/r/subaru/comments/7fi202/2018_radio_hidden_menus/How do you access hidden menus?
You must have the very latest firmware. I'm not sure this is a perfect solution though, see: https://www.subaruxvforum.com/forum...mware-looks-like-post1970680.html#post1970680mine did the same. But found out that if you push the volume control button in and hold it for 3 to 5 seconds the radio will turn of and the display goes blank. Next time you start the car radio will be off.
Yes, but I don't understand why we have to shut off the entire entertainment system and display just to get the radio to stay turned off. There have been SO many complaints about this, it's disappointing that it wasn't properly addressed in the latest firmware release.Push the radio volume control knob in for three to five seconds . The radio turns off and display goes blank
There is a brand new one. See: https://www.subaruxvforum.com/forum...mware-looks-like-post1970692.html#post1970692Astro, what is the latest firmware version numbery thing?
And will you also get the firmware update on your Crosstrek...?I need to be updated in any aspect.
Yeah I was aware of all that, Have you seen this sticky?just want to give some suggestions.
0 the radio is made by Harmon kardon, own by Samsung. Not a lot Subaru can do to fix the problem by HK (definitely not Heckler und Koch)
1 back up camera is integrated into the head unit. It need to be on when you start your car, otherwise, no backup camera.
2 the AA (Android Auto, not alcoholics anonymous) and AC (alway cocked-up, not apple Carplay) map volume can be adjusted separately from radio/cd volume. Please read the manual. It is in there.
3 the volume will stay at last level when you turn off the engine. Just turn the volume to 0 or 1 and you will not hear anything you don’t want.
4 press and hold the volume knob for 3 sec, it will turn off the head unit. But it will turn back on when you restart your car.
5 starlink is on the same fuse as the radio. So, if you pull the radio fuse, you may disable the starlink and car may not be happy. I say “may” because I have not tried it myself yet.
If you don’t like the head unit, take it to a radio shop replace the head unit and Good Luck!
