p0141 Not Clearing
1 reading
13K views 13 replies 6 participants last post by  77'911
While I DON'T have a 2019 FSM, I do have MY14 and MY24. On the 2014, +12 comes thru a relay, then a fuse in the extra fuse strip next to the inside fuse box then to BOTH Oxygen sensor heaters. The ECU controls and sense the ground to turn on the heaters. Extra fuse strip described in this thread: https://www.subaruxvforum.com/threa...com/threads/additional-fuse-block-right-of-interior-fuse-box.72626/#post-960114
MY24 is different. No relay, From the Main Fusebox under the hood, Fuse #17 supplies +12 to both sensors and again the ECU senses and supplies ground.
I would think the 2019 would be no different in that +12v is supplied to the Oxygen sensors and the ECU monitors and controls ground. If anyone has access to a 2019 FSM, they can help with what fuses or if a relay is involved in getting +12 to both sensors.
