As I assumed, his engine didn't die because of too much highway driving with thin oil.
As I assumed, his engine didn't die because of too much highway driving with thin oil.Three years so 200K/yr. He is, or was, a medical courier. I don't know if he was delivering body parts or supplies. From his posts it seems it was mostly highway.
Yes, but Wolverine put on 10,000 miles in a month, or thereabouts.And changes at 10K. He posted some Blackstone results, too.
Certainly the most extreme I've ever read about. He wouldn't have to worry about fuel contamination.Yes, but Wolverine put on 10,000 miles in a month, or thereabouts.
Even more evidence that it's cold starts that ultimately kill an engine.Yes, but Wolverine put on 10,000 miles in a month, or thereabouts.
Good to know! You could also have the oil tested when you change it to see if you could go longer next time.Here we drive a 2016 Crosstrek with really few miles, just over 18k miles over six almost seven years of use. Always Mobil 1 5w30 every year, around 3k miles per change of oil and filter each time. This Xv lives at 8200 feet over sea level and climate around 68f rarely reach 32f. No oil usage so far, oil never loses an ounce. Owner´s manual recommends 0w20 oil. We are planing change to Mobil 1 0w20 oil, next oil change. This is my son´s vehicle.
On the other side, and at sea level and much warmer, around 60-95f all year long, my wife and I drive two 2019 Toyotas, a Camry and a Rav4 both 2.5 liters 4cyl engines. This two vehicles used 5W30 dino oil from Toyota dealer since brand new until last year that I change it my self and used what owner´s manual recommends: 0w16 oil, from Mobil 1. When I switch oils, I measure oil temperature development from first start in the morning to reach normal engine temprarature, my results were: 0w16 oil stay 2 to 3 f cooler than same use with 5w30 oil. Miles per gallon are about the same with both oils on both vehicles even on hot summer. No use of oil so far, at 5k miles oil changes.
All three vehicles are city driving, except the Camry that I have reach 120 mph in a nice hwy to local airport, it drives beautifully and very silent with 0w16 Mobil 1 oil.
One thing that is very important in this engines (Subaru FB20 and Toyota A25A) is the variable valve time system that both engines use, and IMOO one of the main reason car manufacturers recommend thin oils now a days.
This is my own experience that I gladly share with this marvelous forum, best wishes from México my friends.
They may have reorganized the manuals and forgotten to update the wording. The warranty manual has a table that includes oil changes.What puzzles me is this page from the 2024 manual. It says the "following table"... so where is this table or am I misunderstanding something?
I'm in Phoenix, so we have "hot" weather. 0W-16 seems way too thin in 115 degree weather. The manual states "in hot weather, oil of higher viscosity is required to properly lubricate the engine.
I'm in the Tucson area with two Subarus spec'd for 0W20. FWIW I run 0W30 in the summer.I'm in Phoenix, so we have "hot" weather. 0W-16 seems way too thin in 115 degree weather. The manual states "in hot weather, oil of higher viscosity is required to properly lubricate the engine.
The number after the W is the viscosity at operating temperature, so it shouldn't matter if you're in Anchorage or Phoenix.I'm in the Tucson area with two Subarus spec'd for 0W20. FWIW I run 0W30 in the summer.
Then why would Subaru say "Oils of lower viscosity provide better fuel economy. However, in hot weather, oil of higher viscosity is required to properly lubricate the engine."The number after the W is the viscosity at operating temperature, so it shouldn't matter if you're in Anchorage or Phoenix.
Lower viscosity oils will impede the engine less but not protect it as well. It's one way automakers are struggling to meet CAFE standards.Then why would Subaru say "Oils of lower viscosity provide better fuel economy. However, in hot weather, oil of higher viscosity is required to properly lubricate the engine."
Can you enlighten me as maybe I'm missing something?
So for my Phoenix summer (hell) application it would be a good choice to run a 0W-20 or 0W-30 as SubaruBill does in Tucson.Lower viscosity oils will impede the engine less but not protect it as well. It's one way automakers are struggling to meet CAFE standards.
A lot of engine wear occurs at startup before the oil begins circulating. Lower weight oils will have drained off more. The number before the W is the weight when cold so they should be the same. The number after the W is the viscosity at operating temps which should be the same if you're in Phoenix in the summer or Anchorage in the winter.So for my Phoenix summer (hell) application it would be a good choice to run a 0W-20 or 0W-30 as SubaruBill does in Tucson.
More of a question. Operating temps should be similar if you're in Alaska in the winter or Phoenix in the summer but the starting temp will be very different.So you are saying that for us in a hell-hot climate, a 5W is more beneficial than a W30? (not arguing)
This is what I was thinking. The cooling system keeps the engine at a consistent temperature regardless of outside temp.More of a question. Operating temps should be similar if you're in Alaska in the winter or Phoenix in the summer but the starting temp will be very different.
Too many variables for us mere mortals, LOL!This is what I was thinking. The cooling system keeps the engine at a consistent temperature regardless of outside temp.
The argument that higher viscosity oils make a thicker layer between engine parts and therefore protect better is a valid one in theory.
But somehow Wolverine's Crosstrek engine went 600K miles on the Subaru recommended 0W-20 oil with his 10K mile oil changes.
At the other end of the spectrum, a thinner oil will protect better during cold starts in sub freezing weather. The other thing I see is that an oil that makes your car more fuel efficient will mean that engine is doing less work in a given time which means better longevity.
This has yet to be proven.CAFE probably has the manufacturers sacrificing engine longevity.
