Total overkill for most daily use unless you have a lot of Auxiliary lighting or accessories. But even then it still is.Or upgrade to an AGM...
I disagree. They tolerate heat, cold and abuse (e.g. being discharged) better and they also last longer so the cost over time is negligible. Consider it an upgrade, like mudflaps...Total overkill for most daily use unless you have a lot of Auxiliary lighting or accessories. But even then it still is.
I'll agree, everything you said is true. I'm only speaking from my experience. I used to be a low voltage auto tech. The only time we ever sold an AGM to our customers was at their request, and in most cases they would absolutely never need it.I disagree. They tolerate heat, cold and abuse (e.g. being discharged) better and they also last longer so the cost over time is negligible. Consider it an upgrade, like mudflaps...
