Slimy dealer crap like this never ceases to amaze me..."your warranty will be void if you don't install a Subaru battery".
She was too busy watching TikTok videos...@AstroKats Big college town (Mizzou). Guess "Advisor" didn't look up from her tablet to see my salty mustache and hair. I graduated from college before most of those kids were even born![]()
Yeah, I agree. That is my plan, to have them replace it until my warranty covers it. When it runs out, I'll buy a better one. I honestly don't mind if it takes a bit longer, it's their reluctance or inability to give me an ETA that is bothering me a lot. Next plan is to call SOA to see if they can figure out if other dealers nearby have the battery in question in stock and if not to at least get me a loaner for the time being. Regardless, this forum is proving to be very informational and helpful. Like I said before, I have almost zero experience with cars, but I am learning a lot here, particularly about OEM batteries and AGM batteries and such. I am gonna read up a bit more on this stuff to get myself familiar with other related terminology.To be clear, not everyone is suggesting that; there's just a little bit of ... fanaticism on the subject that surfaces here regularly. And it's a mischaracterization to call Subaru batteries "crappy" -- they're just typical OEM batteries.
Subaru is very unlikely to help you pay for a third-party battery. I would accept the free replacement from Subaru with the knowledge that if you don't mistreat it, it will serve you well. A few years down the road, you can decide how much you want to spend for your next battery, but with a free battery in the offing now, you might as well hold onto your money till then.
A quick google search revealed that the CCA metric helps with the colder climate like you said. This car has never been outside of Texas, so I am not sure temperature's the culprit here, especially the last few weeks when it's been in the higher 70s.I don't think it's so much that Subaru provided crappy batteries. They are just a bit undersized as far as CCA.
The stock Crosstrek battery has a Group 35 with 550 CCA.
I replace mine with a Group 35 with 640 CCA, better battery for our colder climate.
The problem we had with the 1yo Panasonic OEM battery was in the mountains when it had been 13F overnight. To me, it's worth a few bucks to get a battery that can cope with that. After all, that's one of the reasons we got a Subaru!A quick google search revealed that the CCA metric helps with the colder climate like you said. This car has never been outside of Texas, so I am not sure temperature's the culprit here, especially the last few weeks when it's been in the higher 70s.
No snarkiness taken, LOL!@AstroKats I want to preface this that I'm not being snarky, just genuinely curious. I've read so many times about your ordeal with the battery in the mountains almost not starting, and also have repeatedly read that you don't have a long daily drive with the Crosstrek living in LA and working from home. So I'm curious if you ever put a maintenance charge on it leading up to your mountain scare. Could it have been in poor health from not much use? I'm not doubting that the OEM isn't the best battery, or that you could have had a bunk from the factory unit. I've had mine about a year now with many nights this winter between 0-20's F and it's done well so far. I do top off the charge now and then tho.
Heat kills batteries. After the heat weakens it, it will not start in the cold.A quick google search revealed that the CCA metric helps with the colder climate like you said. This car has never been outside of Texas, so I am not sure temperature's the culprit here, especially the last few weeks when it's been in the higher 70s.
They like the Goldilocks Zone...Heat kills batteries. After the heat weakens it, it will not start in the cold.
I have a '21 Limited and the OEM battery: CCA = 620A. Still have the original battery in New England BTW - I disabled the auto Stop/Start feature. I wonder how much effect that feature has on the battery's life span.I don't think it's so much that Subaru provided crappy batteries. They are just a bit undersized as far as CCA.
They upgraded a lot of features to handle stop/start. Maybe the battery, too.I have a '21 Limited and the OEM battery: CCA = 620A. Still have the original battery in New England BTW - I disabled the auto Stop/Start feature. I wonder how much effect that feature has on the battery's life span.
My 2019 and my 2020 had/have Group 35 550 CCA batteries from the factory. The 2019 has been replaced, the 2020 is chugging along just fine on the OEM battery since birth.I have a '21 Limited and the OEM battery: CCA = 620A. Still have the original battery in New England BTW - I disabled the auto Stop/Start feature. I wonder how much effect that feature has on the battery's life span.
Yes, it's different, but can not find the specs. Part « numberThey upgraded a lot of features to handle stop/start. Maybe the battery, too.
SOA821B200 - Pb000825 battery. Pb001721 battery - Genuine Subaru Part
Genuine Subaru Part # SOA821B200 (SOA821B210, SOA821B220) - Pb000825 battery. Pb001721 batteryparts.subaru.com
Thank you. I got lost in search and posted late before reading recent posts in this thread.The image I attached has the specs
Have you considered a solar panel charger? (didn't you mention you had?) Plugs into the OBD-II port. Cable has a short piggy tail such that the panel can be unplugged without taking the OBD-II connector off and on.No maintenance charge which, btw, is tricky for the millions of us who live in condos or apartments..
Not that I could see...The image I attached has the specs
Model Years 2018 to 2023 - No ETA for battery replacement
"your warranty will be void if you don't install a Subaru battery". Slimy dealer crap like this never ceases to amaze me...www.subaruxvforum.com
Solar charging doesn't work so well in an underground garage. You're right that I tried a solar panel in the moon roof but that didn't work either, too much tint.Have you considered a solar panel charger? (didn't you mention you had?) Plugs into the OBD-II port. Cable has a short piggy tail such that the panel can be unplugged without taking the OBD-II connector off and on.
CCA = 620A image attachedNot that I could see...
