421 - 435 of 435 Posts
Discussion Starter #421
Reactions: R P
2017 and 2021 CrossTrek Limited
Installed latest update on my 2021 Limited w/Nav and HK. In summary, nine packages installed. Of those, many were not maps data, but rather; Nav software update, updating XM, system files update, voice files update, etc. The Map Data package took the longest to load, as one might imagine. So, it appears this load did include software updates of some kind. Haven’t tested it yet as it’s still chugging to load map data as I type this....
Discussion Starter #423
Interesting. Thanks for the update!
I'll add it to the first post...
Reactions: jebinc
Every time I've installed any update from a USB stick, all those packages get installed. I'm not sure that means they were updated or merely written over the old files, newer or not. I've never seen an update performed via USB where only the maps are written to the unit. Now, if you're doing an update via wifi, that's a different story. I updated only a few selected state maps on my 2019 Crosstrek Limited with NAV a few months ago.
BTW, the map downloader program still says 20.28.70 is the latest for my Crosstrek. OTOH, my 2018 Outback Touring with NAV just got an update to 2.20.40.20, and it was installed via USB without a problem.
I meant the new one:
Rel_A2.20.40.20 NAFTA
USA Canada and Mexico_1056_7522_10469
That version is listed in my Map Downlader as being for my 2018 Outback, NOT for my Crosstrek. Weird.
Doesn't make sense. The Rel_A2.20.40.20 NAFTA, USA Canada and Mexico_1056_7522_10469 is now in my Crosstrek with the most recent download and install.
Discussion Starter #427
Yep, and IIRC the Outback didn't get the new Harman HU in the '17 Impreza and '18 Crosstrek but now has a fancier one with a bigger screen...
Can you clarify the Year/Trim of the Crosstrek where you installed this version? What HU version and if you have a Navigation subscription + Harman Kardon sound system.
Discussion Starter #429
This version is for the '18 with nav (i.e. the Gen 3.0 HU with nav and HK) and it seems that subscriptions are good until August next year.
Interesting... I have a 2021 Crosstrek Limited with HU 3.1, Nav + HK, but I only get Rel_UF.20.28.70 available for download at subaru-maps.com and when I check via WiFi there's no update available.
Discussion Starter #431
The '19 Crosstrek got a very slightly upgraded HU, Gen 3.1, and I don't think that has changed since. There's different firmware for the different gens and it's not released at the same time.
RP....I believe you have a 2018 Crosstrek. If so, you appear to have the same HU as I do in my 2018 Outback Touring, NAV with HK. That would explain why Map Downloader says the software for my 2018 Outback is the same as your Crosstrek. OTOH, the latest software for my 2019 Crosstrek Limited, NAV with HK, is 20.28.70 as listed on Map Downloader and is publication dated 2020-08-26. That was apparently only a map update and I did download a couple of nearby state maps via wifi back in September. The version that is still currently on my 2019 Crosstrek is 19.42.70.
I bet he has a 2018 Crosstrek (limited?), NAV with HK.
Discussion Starter #434
Correct. This new version only seems to be for Gen 3.0 with nav.
