1 - 14 of 14 Posts
FYI
Canada spec 2013 limited
3c Temp
day i
Start Car, realize MFD is black.
3 minutes MFD now has some faint horizontal lines
5 minutes MFD now has more lines some vague highlighting of what is normally on screen
15 minutes MFD now has even more lines and some info now sort of legible 25%
25 minutes drive to dealer, info now legible but completely over written by horizontal lines
45 minutes MFD now back to blue colour all info legible, what problem
day ii
7 c Temp
no problem
day iii
just like day i
turning heater/defrost on full has no impact seems to require warm up like old televisions
day iv
just like day 1
Dealer has ordered new MFD.
Anyone else with this situation?
john
Hello from Canadian spec 2013 Sport
Interesting that happened in MFD even through it's made in Japan. I was told it would work with rear view camera but mine doesn't have camera's pre-wire in the rear hatch door (I have already disassembled the 4 pieces interior covers). You are lucky to have limited model where has camera wiring harness ready.
Post us know if it has camera plug-in port on rear MFD.
Depending on the temperature. The connection to the glass display which is usually a rubber strip, is not making full contact with the glass. With extreme swing of temperatures this is causing the rubber strip to expand and con-track. Thus giving you a partial display. I've seen this on electric meters first hand when they first came out in the field. Depending what time of day/temperature some would or wouldn't display readings. In addition it could be possible bad (weak) soider connection, or IC chip . Years ago like in the 50s' it wasn't uncommon to go back to the dealership several times to get all the bugs worked out of a new car. Now in days with so many mechanical and electronic parts. I'm amazed how well everything works without any issues.
The Forester MFD has two plugs, one is an 8 pin, one is a 12 pin. The back up camera input is intergrated into one of these plugs. Haven't had a chance to see if the XV Crosstrek has similar plugs on it's display (US models) that would allow it to be plugged in.
Have a look at this thread...
http://www.subaruxvforum.com/forum/lighting-electrical/767-backup-camera-multifunction-display.html
Installed mine last year... still works!
I was told that the limited crosstrek model has the wiring to use the high grade mfd. Just want to make sure before I attempt to upgrade .
I also have a Limited and can tell you the wiring is not there (had it apart last night attempting to install the Forester cubby LED). Plus you would need the input buttons that mount on the steering wheel, roll connector, etc. Doubt it would be an easy mod.
I find it interesting that the Canadian Limited gets HID's and the Multi-Function display and is only $1,000 more than the US model...
It's a small LED that lights up the cubby in front of the shifter. The mount is in the XV for it...but no wiring.
the RVC should plug into the 8 pin connector, look for threads here there are few, sorry late to the conversation by about 4 years...... a lot of advice on various threads on which of the 8 pins are needed to run the camera and reverse gear etc.
1 - 14 of 14 Posts
