1 - 13 of 13 Posts
Hey guys! Yesterday I was at my climbing gym and when I came out it was dark. When I turned on my car, I though “hmm why is it so dark??” So I got out and low and behold, my low beams were BOTH out. I checked the fuses, they were fine. I check the relay (whose plastic housing fell apart 🙄), it was fine. Swapped with the horn relay, still no dice. My next step is to disconnect the lights and put a test light into the connectors. And if that doesn’t reveal the problem then I’ll probably take it to the dealership since it’s still under warranty.
I swapped out my OEM bulbs for DDM Tuning Saber LEDs last December. They couldn’t possibly be bad already could they?? Has anyone else ran into the problem with Sabers??
stick your oem bulbs in and see if they work. I wouldn't be surprised at aftermarket LEDs going out early. I carry my OEM bulbs in the car just in case.
yeah I switched back to OEM and it works fine. I’m just butthurt that my LEDs went out so fast. What a waste of money.
any suggestions for alternatives?
I replaced my H11 fog lights with LEDs from Diode Dynamics over 3 years ago for $120. They still work fine.
Discussion Starter #7
My understanding, if the aftermarket LED don't have cooling fan, they get very hot and burn out quickly. Good luck at the dealershyt. They could charge you, warranty or not. Its likely they may claim you modified the vehicle with an aftermarket part. :oops:
The LEDs from Diode Dynamics have fans. If you have a problem, and you're under warranty, put the original bulbs in.
I've been running Supernova v.4 LEDs, they're single filament so the beam pattern is really close to the OEM incandescent bulb. The cutoff is really sharp.
Discussion Starter #11
Yeah my DDMs went out. I checked the connectors with my multimeter. I still wanna check the LEDs to see if the fan housings went bad or the actual bulbs. That’s a project for another day tho.
I’ll check em out!! Thanks everyone for the tips!
Discussion Starter #13
Both low beam bulbs died at the same time.
Sylvania Silverstar ZXE.
Lasted 6 months.
Mannnn that sucks. I looked at those when I went to replace my DDMs. Now I’m glad I didn’t go with those. I went with a set I found on amazon with good reviews. 2 months in and they’re still working great. Nineo I think is the brand.
1 - 13 of 13 Posts
