To make a long story short went to change out the CVT fluid. Was kinda concerned since there is no dipstick, and had to have the car in the air (in order to get underneath it) to check that the fluid was even with the fill plug hole. So raised my "Pumpkin" (Orange XV) on jack stands and drained the CVT pan and dropped the pan to clean it and the strainer/filter. The strainer is big but sorry no pic. Once the strainer is out, there really isn't anything there. a rounded tin cover, covers the CVT chain and there is some shifting linkage. The first pic shows the filler hole on the left side of the transmission, near two electrical plugs.
This pic shows the "tin cover" of the CVT chain.
Took the old RVT gasket off the tranny base and pan. Washed the pan and strainer in my parts washer, blew them out and dried them. Installed the strainer. The strainer intake tube goes in the round "tube" looking part under the tranny in pic 2.
Then used Subie RTV on both surfaces; let them get tacky, and installed the pan filled the tranny with Subie CVT fluid till it came out the fill hole. Started the car and let it get hot. Re-checked the fluid, was low added more, let it run. Ran it through the gears and then checked again. added some more till it was filled to the bottom of the fill plug and DONE!! While we were at it also did an oil change and changed out the front differential gear lube with Mobile 1 synthetic 75W/90, Taking out the filler plug for it was REALLY difficult!! The plug must have been put in by a gorilla. We used a 3/8" air impact with 80 PSI, nothing. Used a 1/2" battery impact, nothing. Used a 1/2" air impact with 110PSI, nothing. (Yeah we knew you could fill the front diff with the top breather tube but it is very small and would have taken a longer time). So my helper who is much younger than I and all muscles, with a 1/2" Long breaker bar finally got it lose after a loud "Snap"!! Anyway all is well, lowered the "Pumpkin" and off we went for a test drive, all is ok! In the end we added approx 7.5 quarts of the Subie CVT fluid.
