1 - 3 of 3 Posts
I have 2019 Premium and I bought a set of Morimoto 2stroke 2.0 9005 bulb. I’ve put them in and they flicker on DRL mode. So I purchased their Morimoto anti-flicker harness and it still flickers on DRL mode! High works fine and doesn’t flicker on high beam mode.
What do you guys suggest?
I suggest returning it if you haven't done so already. I installed a cheap LED bulb in that spot and it doesn't flicker.
19 Crosstrek Limited ORANGE
This is due to the low voltage of the DRL. The Morimoto anti-flicker harnesses honestly aren't that great, I see issues with them all the time.I would replace those modules and go with the ones from Xenon Depot.
1 - 3 of 3 Posts
