There's no need to use a factory filter. However, the bypass valve spec is a higher pressure than is typical for non-Subi branded filters. Bypass happens when the filter is obstructed, so raw oil flows without getting filtered. Maybe when the oil is extremely cold this could happen, or when the filter media is gunked up with debris. Without bypass, insufficient oil would flow in these situations.
There are a couple of non-Subi filters with the same higher bypass valve spec. I use those.
