I would guess so! They have pretty deep tread. Should also help against poncture since these are 8-ply. Time will tell.That's a lot of rubber! Maybe helps off road?
I would be shocked if they were 8 ply sidewall. My guess is they are radial tires and load range e, which is equivalent to the load strength of an 8 ply bias tire. However, read the sidewall for actual construction. Tread and sidewall should be listed. Likely 2 ply sidewall, maybe three.I would guess so! They have pretty deep tread. Should also help against poncture since these are 8-ply. Time will tell.
This look is slick as hell. What year Crosstrek is this? Could we get exact links to purchase the Tire/Wheel combo you have here, or a DM would be welcome as well, I might have to steal this look. I also have an Ice Silver Metallic on order.Here’s my new set up, 215/75/15’s with LP Adventure wheels and BFG K02’s, no lift, no rub
View attachment 310256 View attachment 310261
do you have a picture looking down the side Im curious how much your +10 offset is outside the wheel well2021 Base
15" KMC KM708 Bully Wheels +10 offset
215/75/15 Toyo Open Country A/T Tires
No Lift
i like that they stick out a bit could you take a picture down the side standing back a bit? also does that offset cause the car to get dirtier?Do they come with TÜV certificate? They have an +15 offset that would be the only concern I would have, given the fact that you are in Deutschland and the regulations are 👎🏻 Not sure if they would let you get away with Einzelabnahme View attachment 308810
You'll get better results from the thread "WITH LIFT".guys I have a 2015 xv with lift kit and today I try with the maxxis razr 225/60/r17 and the rear tires touch the plastic (on the front side) any tips ???
some mod or something...
Really thanks
