1 - 3 of 3 Posts
Need help figuring out which KO2s will fit on my 2014 crosstrek. I have seen a lot of 2018 fit the stock wheels, but not sure this is the case for the 2014. I heard some people go with 15” or 16” wheels. I just want no significant rubbing and I don’t want to modify the car.
Thank you!
I’m an avid flyfisher woman and need some good off pavement tires.
2014 crosstrek
What kind of off pavement did you have in mind. My off pavement is beach sand. Some do mud, rocks gravel. I had ko2s on my 2014 for about 2 years. Great tires. I replaced them with Falken wild peaks because I realized I really didn’t need such a capable not to mention fairly expensive tire for my needs. I am assuming you are talking about a lift kit when you mentioned modifications. I had an inch and half lift with 215/75 15 with no issues. I would google your stock tire size diameter and that would give you a safe starting point. What is the size of the tires you have on the car now? I’ll help you find a tire size on a 15” rim that will be close. I went from a 15” rim to a 17” rim and kept the identical diameter. Talk to you later.
Needs a Butch car
^ that's good advice. KO2s are legit tires, but very heavy. If you're driving on forest roads and gravel, then something like the falken wildpead trail or the yokohama go15 might be a better match to your needs. They also come in stock and close to stock sizes.
1 - 3 of 3 Posts
