unless your family rat you out how the dealer gonna know? worst case, put in 0W20 before warranty repairs. But I highly doubt they care.
Well, there are 2 proposals there. Tolerances are looser in order to reduce friction in order to increase MPG. Oil viscosity is reduced in order to increase MPG alone. Maybe you're not old enough to have been into roadrace car building years ago, where looser tolerances were used to build race engines so resistance was reduced to get more power out of the engine. But oil used back then was pretty consistently raised to 50 weight. Today, it's become opposite world in order to meet the MPG requirements.Yes.
You do realize that that oil light comes on when the oil is around a quart low, right?Well, there are 2 proposals there. Tolerances are looser in order to reduce friction in order to increase MPG. Oil viscosity is reduced in order to increase MPG alone. Maybe you're not old enough to have been into roadrace car building years ago, where looser tolerances were used to build race engines so resistance was reduced to get more power out of the engine. But oil used back then was pretty consistently raised to 50 weight. Today, it's become opposite world in order to meet the MPG requirements.
In my 13 Crosstrek, we had the short block replaced by Subaru under warranty at 98k miles for oil consumption. Hey, free Legacy loaner car for 2 weeks and a new short block and the valve springs replaced while we're at it. I just did an oil change yesterday at 190k miles (about 90k on the short block) and I've found that if we use 0w 20, the oil light comes on before 3000 miles. What did I do the change with yesterday? 10w 40. This will hopefully get the car 5000 miles until the next oil change without an oil light. If not, yes, I'll up it even more.
And I'm old enough to remember when some car engines inherently burned off the first quart of oil and stayed there. My dad had a 1971 AMC Gremlin which did this throughout its life until it was totalled at 130K miles. The engine was still good.You do realize that that oil light comes on when the oil is around a quart low, right?
I'm old enough (really) and raced and built enough to know a few things, too.
One is, whomever is responsible for a vehicle checks the oil at least every other fill of the tank. Further, should that person find the oil low, to about any degree whatsoever, they top the oil off to the Full mark. No one waits until the oil is a quart low before adding oil for several reasons: Consumer vehicles only hold just enough oil to both supply the engine with oil under all conditions, it is also responsible for cooling the engine... especially the hotspots near the combustion chambers, which is crucial to the machinery's long term life (rings, valve system, for example). The water jackets only do so much.
So running a few thousand miles with a significant percentage of the engine oil missing isn't, IMHO, responsible maintenance. That requires the remaining oil to do it all... which significantly accelerates its aging and reduces its ability to oil and cool.
Subaru's low oil warning light was implemented in the first place to reduce their warranty costs... repairing and replacing engines for the dummies who never checked their oil. It was never intended to be used as a reminder to add oil. It's a warning.
That's what I would expect, especially since the manual says you can use a heavier weight oil.I'm not sold on 0W16 since it is largely a function of fuel mileage and not protection. I asked someone I trust at my dealership about running a heavier grade of oil. They said Subaru never asked them about oil grade when a customer had a warranty claim. But they always asked for documentation for oil change intervals.
