1 - 16 of 16 Posts
2018 Lifted 6-speed Crosstrek
Hey all, got another video up!
We installed the Rokblokz mudflaps on my lifted Crosstrek. If you're not running larger tires like I am (235/75/15), this install is super simple! If you do have some beefier tires like me, there are some extra steps to get them to play nice on the car.
Check it out and let me know if you have any questions!
Link to the flaps (also avail in different colors): https://amzn.to/2MRUywq
225/55 R18 97H standard Limited tires.
Nice vid Thomas. i..
with oem rims/tires at 225/55 18's you are fine and do not need to mod anything.
Discussion Starter · #11 ·
Thanks... btw, do you think I hv to remove the rear rim in order to drill a hole to instalI?
99% sure you will. You MIGHT be able to do it from behind the wheel.
But it was easier to just lift the whole thing in the air and do it. It took longer to remove the wheels than to actually install the rear flaps, so if you can do that, it's cake!
Thanks for your help.. btw, your Crosstrek is awesome.. well done!!
1 - 16 of 16 Posts
