@Doca Do you have any further comments on the PIAA horns that you recommended? Thanks.
Not really.
I looked at several Hellas and a few other companies as well but knew that fancy looks would be unnoticed unless I addressed the grill. I kinda wanted to do it but it wasn't worth it to me.
I can barely see a portion of the upper mounter PIAA's silver label behind the grill but I know where to look. My wife didn't see it until I pointed it out.
I also knew that I'd have to install a new bracket to mount both front and center to get the visible affect of the Hellas. That would have made wiring and mounting easier. Also, it's easy to unclip the lower OEM horn harness.
In the end, I wanted a deeper tone and I got that from PIAA.
PIAA's Superior Bass Horn pipes 112 db (db means almost nothing once installed in the car) @ 330 Hz and 400 Hz.
The Sharp tone M23S announces themselves with 115 db @ 350 Hz and 415 Hz.
I had considered tri-tone Hella Super tone B113 (118db, 300/375/500 Hz) but at 123mm, I was concerned they'd be too large.
